Using Microsoft Teams on macOS, including installation, features, and compatibility
FOUND SOLUTION
Check this out : https://businesstechplanet.com/how-to-disable-microsoft-teams-keyboard-shortcuts/
By accessing the registry editor you can disable all shortcuts on teams (I tend to not use them anyway)
Steps from the page (all props to Saajid Gangat)
- First, you need to open the “Start” menu.
- From there, find and open the “Registry Editor.”
- Input the following in the editor. “Computer\HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\Teams”
- Once the “Teams” registry panel is open, simply right-click and click on “New.”
- Set the key “DWORD (32 bit) value”.
- Name the value “NoKeyShorts.”
- Double click on the newly created key and change “Value data” to 1.
- Press “OK.”
- Finally, restart your computer.
