Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2024-07-01T16:47:55+00:00
    I think MS might be more responsive to twitter rather than this forum.
    2024-07-01T18:25:17+00:00
    So I filled out a support ticket on our Microsoft 365 Admin Center. Support contacted me and they actually remote controlled into my computer and I was remote controlled into our clients guest computer. The support person worked with us for just over an hour to no success. We deleted the account, re-added the account and tried all kinds of things. We ended up capturing the Edge logs which I sent over to the support engineer who said he will get back to me. So, the timer is ticking to see what response I receive. I can say we did check a lot of settings as well in my tenant console to confirm everything was open for Teams guest to join.
    2024-07-02T13:01:33+00:00
    So.... after working with Microsoft support yesterday a few times and over two hours, they finally gave me this service outage alert. It started on June 4, 2024. Doesn't explain too much, but does mention "Add a member to a team" and what I was given why it is not working right now.
    Some users may be unable to perform multiple functions in Microsoft Teams
    Issue ID: TM801268
    Status: Service degradation
    Start time: Jun 4, 2024, 9:00 PM EDT
    User impact
    Users may be unable to perform multiple functions in Microsoft Teams.
    Impact isn't client specific and may occur on the new and classic Microsoft Teams clients.
    Affected users may be unable to perform the following scenarios in Microsoft Teams:
    • Create a team from an existing group.
    • Add a member to a team.
    • Create a team or channel from a template.
    • Duplicate a team.
    • Archive and unarchive a team or channel.
    • Share a channel with a team.
    • Delete team will not delete all channels in a team.
    • Newly created teams from Graph will not have members added.
    • Clone a team. - Restore channels in a team.
    • Members won't be auto synced between groups and teams.
    Scope of impact
    This issue may impact some users performing one of the Microsoft Teams actions outlined in the More info section.
    Root cause
    An update affected a portion of infrastructure that processes various Microsoft Teams actions, as outlined in the above in the "More info" section, which caused processing delays and a subsequent backlog.
    Updates
    Jun 28, 2024, 2:27 PM EDT
    Our operation to process the backlog of requests is in its final stages, and the majority of delayed requests are now processed; however, the final stage of the operation is taking longer than expected. We're investigating the remaining requests to identify whether the delay is the result of a service issue and to assist us in expediting remediation.
    Next update by:
    Tuesday, July 2, 2024 at 4:00 PM EDT
    2024-07-03T14:22:00+00:00
    Microsoft support called me this morning and said to add the guest by using the website https://teams.microsoft.com/v2/. I just tested doing it this way and so far everyone I am adding as a guest is receiving the email invite and able to connect into that Team site and chat only via the web browser on their end.
