Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2024-01-08T20:51:59+00:00
    It finally just worked for some reason. Didn't really do anything. I think it has something to do with the intrusive microsoft policy encroachment. It's gets more and more like Big Brother every year. It had linked my whole PC to my school. I never asked for that at all.
    2024-01-10T12:26:53+00:00
    very good
    2024-01-10T15:38:52+00:00
    Thanks vey much, looks like this worked for me.
  4. Deleted
