Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2020-09-23T06:21:25+00:00
    Possible resolution.
    In Windows 10 > Settings > Accounts > Access work or school , find the account you're attempting to use to sign into Teams. If it's not here add it. If it is here, disconnect and then reconnect your account. I've tried every other suggestion on this tread and on other postings online. Doing this fixed my issue immediately.
    Thanks it work..
    As there was important work today
    2020-09-23T06:22:19+00:00
    Hi, Please do the following it worked for me and successfully running without any issue
    reconnect your account by disconnecting or adding the one if its not there
    Thanks for it
    2020-09-25T00:46:48+00:00
    Thank you, this worked for me - on laptop Windows 10 and 64bit Teams.
    2020-09-26T11:56:38+00:00
    HI, if you want to fix this problem
    then go in settings, then accounts then access work and school accounts
    disconnect that account in which you have signed in Microsoft Teams..
    ------------------------------------------Thanks-------------------------------------------------------------------
