Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2022-11-23T12:10:47+00:00
    Sure, I have read about such disconnection from work account. But I have yet to figure out how to do that. After much time wasted on research, I have given up.
    What does that even mean, "work account in your computer"?
    2022-11-23T13:09:37+00:00
    2022-11-23T14:16:21+00:00
    Thank you. As you might imagine, I have already googled such articles. But like this linked one, none of them has enlightened me. I do not have and never had a school or work or other organizational account. So, I have learned how I could create one, but why should I. Then, if I have no such account or am connected to one, how can I disconnect. Maybe I am connected somewhere without my knowledge. But how would I find out about that?
    2022-11-24T13:53:26+00:00
    Two years on and this solution still works.
    For whom this solution doesn't work, please remember to restart after you make these changes; it certainly doesn't hurt to try, and it didn't work until I did.
    Thanks Todd.
