Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2022-03-15T21:54:42+00:00
    I tried everything I could find on the web; clearing cache, reinstalling, re-add account in settings and nothing worked. Then I finally closed out of OneDrive and Teams worked immediately afterwards. Just go into the hidden icons on the bottom right, right click OneDrive and close. Hope this helps some of yall.
    2022-03-16T10:16:04+00:00
    Hi i am facing this issue but i try to uninstall and reinstall again and again almost 5 times, it still doesn't work on my this school email. but other email is working.
    Then i try to search the apps data on my file, I cant find it.
    How to solve it
    2022-03-16T16:30:00+00:00
    If you go back a few pages there is a bash script.. basically you need to remove your stored credentials, uninstall, delete files, then reinstall. You'll also have to repeat this every time you shut down your PC. There is a website that you could use instead. It won't work as well for meetings and is missing many of the features.
    Microsoft has in-arguably demonstrated that they are not going to address bugs. There are smaller bugs that have been ignored for a longer time. I believe that until the users show Microsoft that there is a financial or competitive disadvantage to ignoring bugs there will be no fixes forth coming.
    2022-03-25T13:47:57+00:00
    Thank you. Nuking everything in %appdata%\Microsoft\Teams\ worked, while the 'selective delete' and 'connect account' suggestions did not.
