Teams Error - "We're sorry -- We've run into an issue"
2020-04-07T12:43:38+00:00
When opening Teams I get this error
Reinstalling fixes the issue for a day or so, then it starts back.
2020-04-07T13:16:02+00:00
Hi GeorgeRoberson,
Since reinstall Teams can temporarily fix this issue, you can try to sign out and kill Teams from Task Manager to see how it goes.
If the problem persists, you can try to clear Teams cache to see if it can help:
1.  Fully exit the Microsoft Teams desktop client. You can right click Teams from the Icon Tray and select ‘Quit’ or run Task Manager and fully kill the process.
2.  Go to File Explorer, and type in %appdata%\Microsoft\teams.
3.  Once in the directory, you’ll see a few of the following folders:
 a.  From within ‘Application Cache’, go to Cache and delete any of the files in the Cache location.
    *   %appdata%\Microsoft\teams\application cache\cache
 b.  From within ‘Blob_storage’, delete any files that are located in here if any.
    *   %appdata%\Microsoft\teams\blob_storage
 c.  From within ‘Cache’, delete all files.
    *   %appdata%\Microsoft\teams\Cache
 d.  From within ‘databases’, delete all files.
    *   %appdata%\Microsoft\teams\databases
 e.  From within ‘GPUCache’, delete all files.
    *   %appdata%\Microsoft\teams\GPUcache
 f.  From within ‘IndexedDB’, delete the .db file.
    *   %appdata%\Microsoft\teams\IndexedDB
 g.  From within ‘Local Storage’, delete all files.
    *   %appdata%\Microsoft\teams\Local Storage
 h.  Lastly, from within ‘tmp’, delete any file.
*   %appdata%\Microsoft\teams\tmp
Once the cleanup is finally completed, you can now restart Teams and check the results.
Best Regards,
Sylvie
259 additional answers
    2022-01-18T14:03:39+00:00
    The fact that this fails on Mac tells us that the error is in the software. These fixes are touching the symptoms not the issue.
    Based on other bugs listed on this site and judging from MS's inability / willingness to address them I'd suggest that Mac users use the URL: https://teams.microsoft.com
    2022-01-25T18:43:34+00:00
    Try reinstall Microsoft Edge WebView2: https://developer.microsoft.com/en-us/microsoft-edge/webview2/#download-section
    It helped me.
    2022-01-25T19:01:39+00:00
    Thanks, I already did that. What got Teams to finally work was uninstalling and re-installing 4 times, making sure to yank out every vestige of it in the Users folder.
    2022-01-26T01:35:29+00:00
    it says We’re sorry but you don’t fulfill the requirements to create an account at this time whenever I try to create an acount on geforce
