Volume too loud in Teams IOS when using AirPods Pro even when set to minimum volume
2020-07-15T03:30:15+00:00
Hi all,
Anyone can propose a fix to a loo loud volume in Teams even when volume is set to minimum?
I’m using AirPods Pro to join Teams’ calls through my iphone and/or ipad. The volume is set to absolutely minimum possible and it’s still a too loud to the point of causing pain if connected for a prolongued time.
It seems to be a Teams’ behaviour as the airpods function well in other apps in the same devices, enabling me to further reduce the volume. For context, the 50% volume of other apps sound like the bare minimum volume of Teams..
Microsoft Teams | Microsoft Teams for business | Teams on mobile devices
    2021-08-24T11:46:12+00:00
    No problem. Just trying to figure out what might cause the issue for others - me including. The volume seems to be fixed to some lower limit and either my AirPods are very sensitive or my ears. Knowing my hearing loss is quite significant, I would assume the issue is with the equipment. :)
    Happy holidays, Richsb.
    2021-11-17T17:37:37+00:00
    I have the same issue. But it using a Windows 10 Professional Lenovo ThinkPad notebook PC.
    2021-11-30T19:15:50+00:00
    Here is the fix that permanently solved this problem for me. Good luck.
    https://www.reddit.com/r/airpods/comments/b6l5bm/airpods\_2\_windows\_10\_max\_volume\_fix/
    2021-12-01T09:45:56+00:00
    Please note that the issue is on iPhone. I think your link leads to a Windows registry fix. There is no Registry in phone.
    2021-12-01T17:13:43+00:00
    By applying the fix in windows registry it fixed my problem. I was connecting my AirPods Pro to a laptop running Microsoft Teams. By applying the fix windows gave me an option to adjust AirPods Pro’s volume within windows. This option was missing before the fix.
