Volume too loud in Teams IOS when using AirPods Pro even when set to minimum volume
2020-07-15T03:30:15+00:00
Hi all,
Anyone can propose a fix to a loo loud volume in Teams even when volume is set to minimum?
I’m using AirPods Pro to join Teams’ calls through my iphone and/or ipad. The volume is set to absolutely minimum possible and it’s still a too loud to the point of causing pain if connected for a prolongued time.
It seems to be a Teams’ behaviour as the airpods function well in other apps in the same devices, enabling me to further reduce the volume. For context, the 50% volume of other apps sound like the bare minimum volume of Teams..
Microsoft Teams | Microsoft Teams for business | Teams on mobile devices
    2021-03-12T19:00:51+00:00
    I’ve replied to your problem regarding IOS as well. See above
    2021-03-12T19:10:03+00:00
    Hi Richsb, if you’re referring to the screenshot of control center with the AirPods volume, that actually doesn’t do anything for the call in Teams for me. That’s the root of the issue here. We can turn the volume all the way down, but the teams call volume stays overly loud through the AirPods. ¯\_(ツ)_/¯
    2021-03-12T20:13:13+00:00
    No idea then because it works perfectly fine for me. I’m running AirPod Pros on an iPhone 12 mini.
    2021-03-26T17:28:34+00:00
    I am having this problem on iOS too. Teams Volume will not go below 10% and is very loud on Airpods Pro.
    2021-03-26T17:51:33+00:00
    Just go to control centre and turn it down, the volume buttons on the side don’t work
