Volume too loud in Teams IOS when using AirPods Pro even when set to minimum volume
2020-07-15T03:30:15+00:00
Hi all,
Anyone can propose a fix to a loo loud volume in Teams even when volume is set to minimum?
I’m using AirPods Pro to join Teams’ calls through my iphone and/or ipad. The volume is set to absolutely minimum possible and it’s still a too loud to the point of causing pain if connected for a prolongued time.
It seems to be a Teams’ behaviour as the airpods function well in other apps in the same devices, enabling me to further reduce the volume. For context, the 50% volume of other apps sound like the bare minimum volume of Teams..
Microsoft Teams | Microsoft Teams for business | Teams on mobile devices
    2021-02-15T16:48:59+00:00
    Works perfectly! Just change the mic to the default device (i.e computer), then make sure the headphone is set to stereo. Easy 👍🏻👍🏻👍🏻
    2021-03-12T11:59:11+00:00
    NOT FIXED!!!
    This issue is FOR Teams IOs!! Not using on another device.  STILL have the issue where volume is loud on Teams IOS but to people on the call I sound like I'm in a well.
    2021-03-12T12:05:56+00:00
    Yes i have this issue with teams on all devices. my windows pc, macbook and iphone. Seems to be a fix that microsoft doesn't care about.
    2021-03-12T12:08:47+00:00
    NO! You didn't read the actual posted issue!
    This original issue is for TEAMS iOS!!! NOT WINDOWS! We know there's poor control for Windows as well - there are 1,000 other posted questions with this solution given; even a few improvement requests - but I do wish the replies would focus on the use of Teams iOS!
    The youtube post is a fix for an issue on WINDOWS that is not even relevant to this original issue - iOS.
    Does ANYONE know how to fix issue with Teams iOS as ORIGINALLY ASKED????
    2021-03-12T12:18:00+00:00
    Jesus, you need to chill out. Look at the image I have posted with a big red arrow pointing to where you control the volume to your AirPods.
    I hope this helps and you can now calm down a bit. Have a nice weekend.
