Connect-MicrosoftTeams not working
2019-09-21T21:59:22+00:00
Hi Team, Please advice am i doing something wrong
PS C:\WINDOWS\system32> find-Module -Name MicrosoftTeams
Version    Name                                Repository           Description
1.0.2      MicrosoftTeams                      PSGallery            Teams Cmdlets module
Installed module using - install-Module -Name MicrosoftTeams.
Getting error when run     Connect-MicrosoftTeams
PS C:\WINDOWS\system32> Connect-MicrosoftTeams
Connect-MicrosoftTeams : The term 'Connect-MicrosoftTeams' is not recognized as the name of a cmdlet, function, script
file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct
and try again.
At line:1 char:1
  • Connect-MicrosoftTeams
    + CategoryInfo          : ObjectNotFound: (Connect-MicrosoftTeams:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
    2020-04-10T15:13:57+00:00
    I was able to troubleshoot this by running Import-Module after I instaledl the MicrosoftTeams module. I believe I also had to set the scope to "CurrentUser" a couple of times but, it now works.
    2020-05-24T20:39:42+00:00
    I was having the exact same issue. Ver 1.0.0 worked like Ashka123 indicated but I needed a cmdlet that exists only on 1.0.6.
    In trying to solve the issue I installed and uninstalled the module several times but I always had to close and open PowerShell again because it said that the module was in use.
    Now, I'm not sure if this is normal or not but, that's how I got Connect-Module MicrosoftTeams to work; I installed the module, closed PS, opened PS as admin and then it worked.
    I had also changed ExecutionPolicy from Restricted to AllSigned.
    Hope it helps
    2020-06-24T18:31:15+00:00
    After installing and importing the module, closing and re-opening powershell finally allowed me to use the Connect-MicrosoftTeams command.
    2020-08-11T13:32:49+00:00
    This is typical Msft garbage. If they're going to force us to rely more on powershell to compensate for their deficient ui design skills, the least they could do is make sure ps is reasonably simple to use. But no, as usual, the instructions Msft provides are wrong, and you have to wade through endless articles and forum posts and still nothing works as promised. That's what we call the Msft black hole. And here I am, in it again.
    2020-10-24T19:38:14+00:00
    It's ridiculous. Non of MS solutions work. It is jus impossible to run MicrosoftTeams module on some machines with Windows 10. I have 3. Works fine only on one of them.
    No support, no solution, no possibility to "refresh"/"reinstall" powershell, purge modules etc. because it is "integral part of the system".
