Connect-MicrosoftTeams not working
2019-09-21T21:59:22+00:00
Hi Team, Please advice am i doing something wrong
PS C:\WINDOWS\system32> find-Module -Name MicrosoftTeams
Version    Name                                Repository           Description
1.0.2      MicrosoftTeams                      PSGallery            Teams Cmdlets module
Installed module using - install-Module -Name MicrosoftTeams.
Getting error when run     Connect-MicrosoftTeams
PS C:\WINDOWS\system32> Connect-MicrosoftTeams
Connect-MicrosoftTeams : The term 'Connect-MicrosoftTeams' is not recognized as the name of a cmdlet, function, script
file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correct
and try again.
At line:1 char:1
  • Connect-MicrosoftTeams
    + CategoryInfo          : ObjectNotFound: (Connect-MicrosoftTeams:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
    2021-04-09T00:34:47+00:00
    Most likely the reason is the meanwhile un-supported TLS 1.0 and 1.1. but it may still be the setting for some PowerShell versions. To work around:
    Set-ItemProperty -Path 'HKLM:\SOFTWARE\Wow6432Node\Microsoft.NetFramework\v4.0.30319' -Name 'SchUseStrongCrypto' -Value '1' -Type DWord
    Set-ItemProperty -Path 'HKLM:\SOFTWARE\Microsoft.NetFramework\v4.0.30319' -Name 'SchUseStrongCrypto' -Value '1' -Type DWord
    Then exit and re-start PowerShell as admin.
    It did the job for me.
  2. Deleted
    2021-05-09T13:58:58+00:00
    Sweet. Worked like a Charm !!
    I didn't have to downgrade MS Teams module.
    2021-06-08T08:22:03+00:00
    It worked for me like this:
    1. Install module in Administrator's powershell
    2. Then run powershell as user
    PS C:\Users\t> Set-ExecutionPolicy -ExecutionPolicy RemoteSigned -Scope Process
    Execution Policy Change
    The execution policy helps protect you from scripts that you do not trust. Changing the execution policy might expose
    you to the security risks described in the about_Execution_Policies help topic at
    https:/go.microsoft.com/fwlink/?LinkID=135170. Do you want to change the execution policy?
    [Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "N"): y
    PS C:\Users\t> Import-Module MicrosoftTeams
    PS C:\Users\t> Connect-MicrosoftTeams
    (asks for credentials)
    Account                       Environment Tenant                               TenantId
    Worked for me, thanks!
    2021-06-17T11:25:19+00:00
    I've come across this issue, and I've discovered it's because my profile is on a UNC path, and if I've run as Administrator (as instructions invariably do...), I lose permissions to access the UNC path.
    The best solution for me is to either avoid using Administrator privileges or just use a local profile if needing to escalate.
