Managing sound and video settings during Teams meetings and calls
It's amazing how incompetent Microsoft is about this. The only app I ever had that can't produce sound to any Bluetooth device.
I am using Teams app android to attend my online classes but I am facing issues with bluetooth speaker. I wanted to use Nest mini for audio output so I paired to it through bluetooth on my android device and audio output of all the apps work except teams. This issue seems to be only on android app because on the desktop app on windows 10 the same speaker works absolutely fine. In the android app when I try to switch the audio output to bluetooth, within a second it switches back to device audio. I tried on another android device as well but no luck. I am running the latest teams version (as no updates available in Play store). Any help is welcome.
I was having this issue as well.
What worked for me:
Yes, you also have yo delete the storage.
Kad
Thanks Kurt, it helped.
I still think it's something Teams should address automatically.
I was facing the same issue, weirdly when I switched to speaker the Bluetooth device started working
