Managing sound and video settings during Teams meetings and calls
I experience the same my bluetooth head set working perfectly in all android apps, EXCEPT TEAMS
I am using Teams app android to attend my online classes but I am facing issues with bluetooth speaker. I wanted to use Nest mini for audio output so I paired to it through bluetooth on my android device and audio output of all the apps work except teams. This issue seems to be only on android app because on the desktop app on windows 10 the same speaker works absolutely fine. In the android app when I try to switch the audio output to bluetooth, within a second it switches back to device audio. I tried on another android device as well but no luck. I am running the latest teams version (as no updates available in Play store). Any help is welcome.
Uninstall and install again the Teams App and problem solved!
Still experiencing this issue, seeing it's still ongoing after more than 2 years is hilarious. I managed to use my Sony Linkbuds for just one call with a random combination of uninstall/reinstall, deauthorize/authorize, pair/unpair etc., but I am not aware of and should not ever do any procedure other than connect/disconnect or switch off and on Bluetooth output. Headphones work with every other app and with the computer, so only problem here is that you need to fix this app.
I have same issue.
This works for me. Thanks for the solution.
Don't forget to restart the app.
