Microphone very quiet on Teams
2020-03-27T09:28:13+00:00
My in built microphone on my laptop works well with other  and is good on the voice recorder but I cannot take part in audio conversations on Teams because others in the conversation cannot hear me. I have tried settings on Teams and on my laptop control panel but haven't been able to fix the problem. Can anyone help?
Thank you in advance.
Microsoft Teams | Microsoft Teams for education | Teams and channels | Other
    2020-09-17T14:21:24+00:00
    Same problem for me.
    Since I updated system to Win 10 1909
    Everything was working well in 1803.
    Now i have this issue in teams. No problem at all in Skype or other tool.
    System is a Dell XPS. Audio drivers have been re installed but still exactly the same.
    2020-09-17T14:54:33+00:00
    I also have a repro of this problem, and mayhave a workaround, by changing the default audio format for the microphone.
    Try going to legacy Control Panel / Hardware and Sound / Manage Audio Devices, then click on the Recording tab, then click on your microphone device, and click the Properties button below.  In the Advance tab, try changing the default format of audio... my PC was recording at 44100 Hz, and changing to 48000 Hz resolved the microphone gain problem in Teams.
    2020-09-24T20:54:21+00:00
    I too am having the same issue...  zoom and support assist on my dell 3410 works fine.   Teams is quiet and I cannot adjust the sample rate on the device.  It shows only 1 channel where as my dell 7470 shows 2 channels at 48,000hz.
    I have been on the phone with teams support to no avail for hours today...
    2020-09-25T16:50:09+00:00
    Exact same issue with Dell Latitude 3510.
    2020-09-29T07:30:11+00:00
    Dear George,
    The moment i make a test call it works fine. That is the only way for me to use my microphone.
    I start a test call and mute it so other people can hear me trough other applications.
    If i don't start a testcall my microphone volume plummets down to 1% and no other way to change it.
    Please respond, this has been know since march now and people still have problems with it.
    Regards,
    Dennis
