How to fix a blue background with white dots on windows 10
Jet 0 Reputation points
2025-07-13T16:25:35.29+00:00
Whenever I log in the background disappears and is replaced by a blue background with white dots and lines
Windows for home | Windows 10 | Desktop, Start, and personalization | Screen saver
  1. DaveM121 935.1K Reputation points Independent Advisor
    2025-07-13T17:04:07.33+00:00
    1
    That usually indicates there is a problem with the graphics drivers.
    Go to the support page for your PC on the manufacturers website, then from there, download and re-install (not update) the version of graphics drivers they provide, then restart (not shut down) your PC and check if that resolves the problem.
    2
    If that does not resolve the problem.
    Open File Explorer, then paste this into the address bar and press Enter.
    %AppData%\Microsoft\Windows\Themes
    In the resulting folder, delete the Transcodedwallpaper file(s) and also delete the contents of the CachedFiles folder
    Restart (not shut down) your PC and set your preferred desktop wallpaper.
