how to fix phone verification problem
rui 20 Reputation points
2025-07-13T08:04:22.54+00:00
so ive been wanting to redeem my microsoft reward since a month ago but this phone verification system is annoying and wouldnt send at all. maybe its because the philippine country code is not supported? how would it be possible to make it so that the philippine country code supported
help would be appreciated
Bing | Microsoft Rewards
John Jefferson Doyon 88,240 Reputation points Independent Advisor
2025-07-13T08:42:45.3633333+00:00
Hi, I'm John!
You're not alone having this issue. I'm on the same country.
The only way to redeem a gift card is by verifying your phone number. If you’re getting an "We don't support that country code" error also, it’s because that this feature has been disabled in some countries including The Philippines.
When I contacted Microsoft Support, they explained that this decision doesn’t come directly from Microsoft and that it may take some time before the issue is resolved.
The best thing you can do right now is reach out also to Microsoft Support to confirm and ask for further clarification.
Here’s how:
Here is the link: https://support.microsoft.com/home/contact
  • Type this keyword and press Enter: Contact Support.
  • At the bottom, click "Sign in to contact support" and sign in with your personal Microsoft account, or click "Contact Support" if you're already signed in.
  • In Product and services, select "Windows".
  • In Category, select "Technical support."
  • Click "Chat with a support agent in your web browser".
If you ever find yourself stuck in a loop, please use the keywords "Contact Support" or "Live Chat" (without the quotes) and click "Contact Support" at the bottom.
I really hope the steps to contact Microsoft support is helpful!.
Regards,
John J.D.
2 additional answers
  1. Levani Kvetenadze 0 Reputation points
    2026-07-05T09:32:05.8866667+00:00
    hi I faced same problem(if you are talking about robux then i had situation where on pc it wasnt showing robux offer but on phone it was showing if you have that problem try to redeem it not from the app but from site. i dont rememeber tho how i did it.
  2. Deleted
