how to fix internal microphone not working
Phyllis G 0 Reputation points
2025-07-13T02:50:28.85+00:00
my internal mic is not working but i can attatch a bluetooth speaker and can then use my voice too search
Microsoft Edge | Audio and video playback | Windows 11
  1. John Jefferson Doyon 86,980 Reputation points Independent Advisor
    2025-07-13T03:31:01.12+00:00
    Hi, I'm John! I will help you with this.
    To narrow down the issue:
    1. Did the mic use to work before, or has it never worked on this device?
    2. Did this issue start after a Windows update or any changes to your system?
    3. Have you tried any troubleshooting steps so far?
    If you haven't tried anything yet please start by:
    Check Microphone privacy settings:
    • When you go to Settings (Win +I) > System > Sound > Input, does it show the correct microphone (like "Microphone Array" or something similar) as the default input device?
    • Go to Settings (Win + I) > Privacy & security > Microphone and confirm that microphone access is allowed for apps
    Test it in Sound Control Panel:
    • Type mmsys.cpl in the Start menu to open the old Sound panel.
    • Go to the Recording tab, right-click your mic, and choose 'Properties'.
    • Check the Levels tab to make sure it's not muted and adjust the volume if needed.
    If the issue persists, please provide more details by answering my questions.
    Click "Comment" below to let me know.
    Regards,
    John J.D.
