WIN11 Widgets not working - "Unable to load weather information"
Matthew Steger 45 Reputation points
2025-07-12T22:08:05.0666667+00:00
I am running WIN11 (latest update available) and, for some reason, my widgets are not working. They had been working until recently. I didn't install any new programs that seem to be related to Widgets not working. I am indeed connected to the internet.. one of the first 'fixes' I found said to ensure internet connectivity, but I am, of course, connected to the internet and done through an ethernet connection.
I watched this video (https://www.youtube.com/watch?v=jVgvRH-Nl50), it showed all sorts of things to try, however nothing in it fixed my issue.
  1. I do have Widgets enabled in my WIN11 settings and, in my taskbar, the Widget icon shows. When I hover over it, it says "No Internet Access". When I left click, "Unable to load weather information. Make sure that the location you have entered is correct. Verify that you are connected to the Internet. Reload". I am indeed connected to the web using my own private ethernet connection (800 Mbps).
  2. I have tried turning off and back on the Widgets option in Settings to no avail.
  3. I have tried turning off the Widgets process in Task Manager to no avail. There is no 'restart' option when I go to Widgets and right click, but only one to close it and some other options, but no 'restart' option. I tried closing it and it does the auto-restart to no avail.
  4. I have tried installing the Webview2 so that I can try to re-install it but when I try to install it, it says it's already installed. If I try to uninstall it in Settings/Apps, there is no "Microsoft Edge Webview" program/app visible to let me uninstall it.
  5. I have tried to uninstall "Windows Web Experience Pack" in the Microsoft Store under Library. It only tells me it is already installed and there is no option to uninstall it. I am logged into my MS account. Also, under my WIN11 Settings/Apps, there is no Windows Web Experience Pack showing to let me uninstall it.
  6. I have run WIN11 update and all available updates are installed already.
  7. I also did temporarily disable my anti-virus program (Norton) as one thing said to try to do to see if Widgets works, but to no avail.
  8. I did a sfc /scannow (System File Checker) in CMD. It did say it found and repaired one or more issues. Widgets still does not work.
No idea what else to try.. everything I am finding in various web searches and videos, I have done but none actually fix my issue.
Seem the only option is to do a WIN11 factory reset which seems a little much just to get a simple widget to work properly so I can see my local temperature displayed in my task bar. That would entail me doing a re-install of all of my installed programs.
Curious if others are solved a similar problem with Widgets in WIN11 and how I can fix my issue.
Anyone help?? Thanks.
Windows for home | Windows 11 | Apps
Yve 435 Reputation points
2025-07-14T05:09:19.43+00:00
Thanks for the update, Matthew! It looks like ExplorerPatcher was causing the problem. Uninstalling it brought your Widgets back, and reinstalling it caused the issue to return, just as others have reported.
This problem has affected many users after recent updates. The latest ExplorerPatcher versions seem to conflict with Windows 11 Widgets, especially the weather feature. For now, the best option is to keep ExplorerPatcher uninstalled if you want your Widgets to work properly.
If you try ExplorerPatcher again in the future, check your Widgets right after installing. If the problem returns, uninstalling it should fix it. The ExplorerPatcher team and users are discussing this on GitHub, so keep an eye on their page for updates or fixes
Thanks again for working through all those steps and for sharing your findings. It looks like you’ve pinpointed the issue, and your troubleshooting will definitely help others who run into the same problem.
6 additional answers
  1. Yve 435 Reputation points
    2025-07-12T23:16:08.2566667+00:00
    Hi Matthew, Thanks for sharing all those details. Let's go through a few more things together.
    Try these:
    Check your Microsoft account
    • Go to settings > Accounts > Your info
    • Make sure you're signed in with a Microsoft account
    • If you are, sign out and back in
    Restart Windows Explorer
    • Press Crtl + Shift + Esc to open Task Manager
    • Find Windows Explorer, right-click it, then click Restart
    Reset Microsoft Store
    • Press Windows + R, type wsreset.exe , press Enter
    • When the Store opens, search for Windows Web Experience Pack
    • If there's an update, install it
    Check Group Policy (if you're Windows Pro)
    • Press Windows + R, type gpedit.msc , press Enter
    • Go to: Computer Configuration > Administrative Templates > Windows Components > Widgets
    • Make sure it says Not Configured or Enabled
    • Restart your PC
    Try a new user account
    • Go to Settings > Accounts > Family & other users
    • Click Add account
    • Log into the new account
    • Check if Widgets work there
    Reinstall Widgets
    • Right-click PowerShell from the Start menu, choose Run as administrator
    • Paste this and press Enter: Get-AppxPackage MicrosoftWindows.Client.WebExperience | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
    • Restart your PC
    Check proxy or VPN
    • Go to Settings > Network & Internet > Proxy
    • Turn off Use a proxy server
    • If you're using a VPN, turn it off and try Widgets again
    Hope this helps! If it doesn't work, let me know there's one more way to fix this without resetting your whole computer, will figure it out.
  2. Matthew Steger 45 Reputation points
    2025-07-13T13:19:51.3166667+00:00
    1. I don't see a sign-in or sign-out option. It shows me logged into my computer as the admin, shows me 1,124 Points under Rewards (making me think that I am logged in to my MS account). Also, when I click on Accounts (under Related Settings), it has me already logged into my MS account, too. I don't use OneDrive so that option has a sign-in option. I have my WIN 11 set up so that I don't have to log-in to my computer every time I reboot it. I've had this setup this way since I bought this computer over a year ago.
    2. Did this and nothing changed. Hovering over the Widget icon in the taskbar still says "no internet access"
    3. There is no update for Web Explorer Pack showing. Only an "Open" option shows.
    4. I am using WIN11 Home (not Pro) so when I search for "gpedit.msc", an error message comes up saying that file can't be found.
    5. Interestingly, when I go to Accounts, there is no "Family & other users" option as you mention. I did add a new account under "Family". I created a new account and can access Widgets normally there.
    6. Re-install Widgets - there is no " " option when I right-click the Start button. These are the options... Installed Apps, Power Options, Mobility, Event Viewer, System, Device Manager, Network Connections, Disc Management, Computer Management, Terminal, Terminal (Admin)... are the only options.
      It did manually run PowerShell as an admin using the search function for "Powershell" and this was the response in the cmd window (I also installed the latest version of Powershell before hand):
      Get-AppxPackage MicrosoftWindows.Client.WebExperience | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"} Add-AppxPackage : Deployment failed with HRESULT: 0x80073D02, The package could not be installed because resources it modifies are currently in use. error 0x80073D02: Unable to install because the following apps need to be closed MicrosoftWindows.Client.WebExperience_525.15301.20.0_x64__cw5n1h2txyewy. NOTE: For additional information, look for [ActivityId] 725fae12-f372-0004-17e4-8a7272f3db01 in the Event Log or use the command line Get-AppPackageLog -ActivityID 725fae12-f372-0004-17e4-8a7272f3db01 At line:1 char:67
      • ... | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.I ...
        • CategoryInfo : NotSpecified: (C:\Program File...ppXManifest.xml:String) [Add-AppxPackage], Exception
        • FullyQualifiedErrorId : DeploymentError,Microsoft.Windows.Appx.PackageManager.Commands.AddAppxPackageCommand
    7. I am not using a proxy (option was already off) and I am not using a VPN.
    Hopefully these answers will help guide us to fixing my Widgets issue. Since Widgets works fine with the other user set up, obviously, it is installed on my machine. Seems to be either a corruption in my settings or something causing it to not work with my main user. I am the only one to use this laptop.
    Thanks.
  3. Yve 435 Reputation points
    2025-07-13T19:36:44.9733333+00:00
    Thanks for the update. It really helps narrow things down. Since Widgets work fine under the new user account, we know the problem is tied to your main user profile and not the system or internet connection. Let's focus on fixing your main profile.
    Close the Widgets app before running PowerShell - the command failed earlier because the Widget app was still open.
    Here's what to do:
    • Press Ctrl + Shift + Esc to open Task Manager
    • Look for anything called Widgets or Web Experience Pack
    • Right-click it and choose End Task
    • Now open Powershell as Admin, then run this comman again:
      • Get-AppxPackage MicrosoftWindows.Client.WebExperience | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
    • Restart your computer and try the Widgets again
    Clear the Widget app's data - this helps if something in the app is corrupted.
    Here's what to do:
    • Open File Explorer
    • Go to: C:\Users\YourUserName\AppData\Local\Packages
    • Find the folder that starts with: MicrosoftWindows.Client.WebExperience
    • Rename the folder (just add .old at the end)
    • Restart your PC and check Widgets again
    Reset Microsfot Store - this can help clear up any hidden issues.
    Here's what to do:
    • Go to Settings > Apps > Installed apps
    • Seach for Microsoft Store
    • Click the three dots (...) beside it > Advanced options > click Reset
    • If you see MicrosoftWindows.Client.WebExperience in the list, reset that too
    Use the new account if needed - if nothing works, you can move over to the new account where Widgets work.
    Here's what to do:
    • Move your files (Documents, Pictures, etc.) to the new account
    • Reinstall any apps you need
    • Sign in to your Microsoft account on that new profile
    Let me know how these go, and will keep working on it together if something comes up.
  4. Matthew Steger 45 Reputation points
    2025-07-13T23:23:22.6566667+00:00
    1. I closed the Widgets processes in Task Manager and then ran the Powershell command again and didn't get the error this time. I rebooted and still get the "No Internet Access" message when I hover over the Widgets box in the task bar.
    2. When I try to rename the "MicrosoftWindows.Client.WebExperience... " folder to amend its name with a ".old", I got an error message saying it can't be done because "the folder or file is open in another program". I went back into the Task Manager and closed all processes named Widget, or similar. Doing that, then let me successfully amend the name of the "MicrosoftWindows.Client.WebExperience... " folder.Rebooting does not fix the issue. A new MicrosoftWindows.Client.WebExperience_cw5n1h2txyewy folder is created and I still get the "No Internet Access" message when I hover over the Widgets box in the task bar after I reboot.
    3. I have no Microsoft Store app installed on my machine. When I search for that name under "Installed Apps", I get a "we couldn't find anything to show here...". I also find no Microsoft Store listed in the list of all installed programs/apps.
    Another observation.. even though it says "No Internet Access" when I hover over the Widgets box in my taskbar, if I left click on it, it says "Unable to load weather information. Make sure that the location you have entered is correct. Verify that you are connected to the internet". Under that is a RELOAD option. If I click on that, a weather window for my area pops up with weather conditions for my area, but goes black and again shows the above message after about 1 sec. Same thing happens repeatedly if I press the RELOAD button. It was doing this before, too, so nothing I did today changed this but figured I'd let you know about this in case it helps you determine what is going on with my WIN11 install.
