VSS (Volume Shadow Copy Service) writes issue
Vítězslav Herman 0 Reputation points
2025-07-09T06:44:28.6866667+00:00
Hi, sorry for delay, I would like to continue in discuss about this issue
https://learn.microsoft.com/en-us/answers/questions/3863521/vss-(volume-shadow-copy-service)-writes-issue?forum=windows-windows_10-other_settings&referrer=answers
Hi, I use Acronis True Image for backuping my PC and now I started to having issue -
"There is not enough space on the volume where the snapshot storage is located"
Acronis support wrote me:
Since you're attempting to create a full PC backup, it requires a significant amount of storage space. It appears you're encountering storage-related issues. I recommend trying a disk-level backup for each individual backup present in your system to see if the issue persists.
Additionally, based on the screenshots and logs you provided, the issue seems to be related to VSS (Volume Shadow Copy Service) writers. As this is a Windows system component, I recommend contacting Microsoft Support to resolve the VSS writer issue. Once resolved, you should be able to proceed with backups successfully.
I am adding screenshot from the Acronis Disk Director.
How can I rise that?
we ended on
you said:
"Please run these commands:
takeown /f "Y:\System Volume Information" /r /d y
icacls "Y:\System Volume Information" /grant *S-1-5-32-544:F /t /c
rd /s /q "Y:\System Volume Information"
Once done, redo the steps listed in that Microsoft article."
so I did, then I went back to this page, as you said in that article and I got stuck on part 11.
https://support.microsoft.com/en-us/topic/-we-couldn-t-update-system-reserved-partition-error-installing-windows-10-46865f3f-37bb-4c51-c69f-07271b6672ac
"Type whoami and press Enter, and then record the user name. Type the following command and press Enter: icacls . /grant <username you got from whoami>:F /t
Note: Do not put a space between the username and ":F", or the command won't work."
it writes "access denied"
příkaz 11 - MS návod - bug
  1. Vítězslav Herman 0 Reputation points
    2025-07-09T10:37:20.1166667+00:00
    This was possible to be done in AOMEI also (the shrinking of C)
    about the reservation partition - i will keep it and extend it in one move, it will take few mbs and will dont have to again theoretically care , if the Acronis would write, that there need to be some free space.
    shrinkC-1
    shrinkC-2
  2. Ramesh Srinivasan 88,105 Reputation points Independent Advisor
    2025-07-09T11:32:45.1066667+00:00
    Hi Vítězslav,
    Ok, let me know how the operation went.
    Regards,
  3. Vítězslav Herman 0 Reputation points
    2025-07-10T08:01:28.68+00:00
    So.. I used the AOMEI to resize the partitions and ended up with Windows blue screen "PC need to be repaired" issue 0xc0000225, with unworking possibility of correcting by the Windows bootable media, issue correcting it via cmd by some bootrec /fixmbr and some other functions.. i was able to recover the disc from my backup :/
  4. Ramesh Srinivasan 88,105 Reputation points Independent Advisor
    2025-07-10T08:05:20.88+00:00
    Rebuilding the BCD can fix the error 0xc0000225.
    Now that you've restored from an earlier image, can you please post the latest Disk Management screenshot?
  5. Vítězslav Herman 0 Reputation points
    2025-07-10T08:11:39.5533333+00:00
    Yes, I used the
    bootrec /fixmbr
    bootrec /fixboot
    bootrec /fixmbr
    bootrec /rebuildbcd
    but then ended up on that the AOMEI partition assistant when booting Windows was still loading and still writing, that there are no other operations need to be done and still restarting to that state.
    I used some command to check, that the AOMEI is not booting, and wasnt able to find it.. so not sure, what to do..
    at the moment I only recovered my disk image to the state, before I used the AOMEI to change the partitions sizes
