Windows 11/Battery dead and not charging
2022-01-01T18:09:19+00:00
I updated to Windows 11. BIG MISTAKE! Now, My laptop battery is dead and won't charge. I see lots of people had problems with the battery not charging, but my battery is dead and so none of those work for me. Will MS pay for a new battery for me since they broke my laptop? Let ne jbiw uf tgere;s aything else I can do short of spending money I don't have on a new battery.
Reading all the comments from people who had this problem, Microsoft knew this was a problem and should have fixed it before releasing it to the public.
    2022-10-25T00:49:31+00:00
    I have same problem and loosing my work
    Please stop blaming it on hardware as before upgrading it to Windows 11 ( while running on Windows 10) my Microsoft Surface laptop never had issue, after upgrading to Windows 11, battery completely dead and I cannot charge my laptop
    Microsoft has to pay compensation to all affected users
    Please take it seriously
    We all can sue Microsoft as laptop is completely unusable and like others I am too loosing my work
    2022-10-25T06:32:05+00:00
    i have the same case, my batterey is broken as soon as update to windows 11
    2022-10-25T15:19:30+00:00
    charge from BIOS if that works loke me it's Windows 11
    2022-11-07T17:30:01+00:00
    I ALSO HAVE A SIMILAR ISSUE. Battery charges till 75% only.
    My battery was not working well so had bought a new one. So this new battery is charging only till 75% exact, every time.
    Any idea what can I do?
    Tried BIOS
    Device manager disabling/uninstalling/updating Power-related things.
    Dell Power Manager settings.
    2022-11-08T10:58:07+00:00
    If not BIOS fix then battery is probably fcd. Window's 11 has much to answer for with battery issues but if you can't make it work 100 percent through BIOS then likely battery is fckd
