I2C HID Driver Touchpad Failure (I think I solved it)
2021-12-12T21:04:07+00:00
If the touchpad on your laptop has failed. You're playing now you see it, now you don't wit TOUCHPAD in your settings. And no customer support can assist you from HP or MSFT, try this it just worked for me...
Go to DEVICE MANAGER
Expand HUMAN INTERFACE DEVICES
And you see 12C HID Device has an error.
If you click DRIVER and then UNINSTAL DEVICE the 12C HID Device is delisted, and on startup it magically refreshes.
I was hoping that would do it, but the TOUCHPAD was still inoperative, and the error persisted.
Then, on a wild thought. I repeated UNINSTAL on all of the HID-compliant Device tabs. My thought was the whole HID Device needed a reboot. As soon as they all delisted, I said a prayer and rebooted.
And my touchpad was finally restored!
I hope this helps others, as this was really frustrating.
Ps. In Touchpad settings (once you can access them again) it's also a good idea to tic LEAVE TOUCHPAD ON WHEN MOUSE IS CONNECTED.
    2021-12-13T18:20:33+00:00
    UPDATE.
    After 10 hours testing, no issues, I allowed the computer to sleep. The TRACKPAD disabled again; however, the error did not reappear in the Device Manager. Deducing the issue was related to hybernation I did a restart and again the Trackpad was functioning.
    I then discovered the true culprit.
    In about half of the HUMAN INTERFACE DEVICES elements there is an additional tab called POWER MANAGEMENT and wouldn't you know it, there's a tic box entitled, "Allow the computer to turn off this device to save power" and that, my friends, is what keeps turning off the Trackpad. Why on earth it's the default setting, God only knows.
    Hop this helps all y'all.
