I think I might have some sort of a solution!
I've been using it for the last couple of hours and it seems to work!
This solution only enables me to use the headphones on hands-free mode (the mode with the low quality audio + mic) so it's not suitable for listening to music or anything like that.
Basically the idea is to trick windows to use the mic all the time, that way the auto switch to audio mode (which was introduced in win11 - see here, and I believe is the one causing this issue) won't trigger and the headphones will remain in the hands-free mode.
Here are the steps I did -
- Preparation Step (only need to do once) do this when you're headphone are disconnected. Not sure if this one is needed but haven't yet tested without it.
- Go to control panel
- Click on Sound (make sure you're not in "View by: category" mode so the Sound icon appears)
- Click on the Recording tab
- Right click and disable each one of the recording devices except for your headphones.
- Day to Day use - we now want the headphones to start in hands-free mode and stick to it
- Once again, open the Sound setting and click on the Recording tab
- Connect your headphones
- Now, the recording tab tries to use the mic on the headphone to display the sound level, so the headphones should be in hands-free mode. As long as you keep this window open, the headphones should remain in that mode.
- You can now go into zoom/google meet/teams/any other video conference app you use
As I said, this worked for me for the past day... even made some zoom calls and people were actually able to hear me again :)
Let me know if this helped you!
