csgo takes +- 20 seconds to start up
2021-12-10T18:17:12+00:00
since yesterday i upgraded to windows 11. everything was fine and worked good. then i started up csgo, noticed it took so long to start up. like 20 seconds what was in win10 only like 2/3 seconds. i tryed to reinstal csgo. steam or even today did a clean reinstal of windows11. the problem did not go away...
it not a hardware problem.. it is a software problem ( win 11) every games runs perfect exept csgo wel if it runs it runs good. but its soooo slow... pleas help me out. i have tryed everything...
Windows for home | Windows 11 | Gaming
    2022-02-17T19:52:09+00:00
    Same, here. I used Windows 11 on Beta and that's already affected me, so i downgraded to Windows 10.
    But today, i trieyd a 2nd chance to Windows 11. It tooks 10 seconds or more to srtart CSGO.
    Ryzen 5 5600x
    8GB 3600Mhz (x2)
    GTX 1070 (The same issue when i tried with RX 580)
    2022-02-18T05:08:54+00:00
    So it is really the Windows 11 issues.
    Either Windows dev or CS GO dev have to fix it.
    It has been a month with no fix, sad.
    Updates: lagging while pressing u /y to chat and in buy menu , after those thing closed no lag. Getting worse...
    Anyone having the same issue?
    I google it and found it happened from the past too, and it can be solved by restarting the CSGO and STEAM, but not this time.
    2022-02-20T01:33:37+00:00
    It issue since beta wind 11 since october release and till now... CSGO starts about 30 secs while win 10 need 2-3 sec before start. Microsoft need fix it.
    2022-02-25T19:12:55+00:00
    Im having the same issue, CSGO starting up terribly slow, that black screen for a few seconds, and also feels like its connecting to the server more slow then before (windows 10).
    running on
    ryzen 5800x
    RTX 3070 TI
    32GB 3600mhz ram
    970 evo plus 1TB MS SSD
    1440p 165hz msi monitor
    gigabyte B550 AORUS pro V2 motherboard
    csgo launch options
    -high -nod3d9ex1 -nojoy -novid
    Have searched and tried everything i found, cant get this resolved. It's damn annoying!
    2022-02-27T22:20:04+00:00
    Same issue here too.
    rx 5500 xt with ryzen 5 3600 and 32GB RAM 3000mhz
