Windows 11- audio long delay before starting
2022-01-10T16:28:10+00:00
After updating to Windows 11 on my 6 month old laptop, my audio files take 20 seconds to start or they do not start at all. This also causes a delay in videos starting whether the file is on my computer or a website. Has anyone else had this issue.
    2022-08-26T14:14:26+00:00
    Not sure this will help people much but I have recently found that when I do not use audio for a while it seems to hibernate and won't restart automatically on my PC. This affects spotify; windows media player, youtube videos, etc (though not Xbox One console games). My work around is to click on the speaker symbol in the lower right corner of my screen and quickly swipe the volume right to 100% and then left back to zero and then to 12%. Sometimes need to do this twcie and it always works. This usually fixes it for the day. I have been doing this for some time now and think it may be related to the audio drivers for Logitech which although identified as Realtek Audio in Device Manager show the provider as Microsoft 10.0.19041 (12 June 2019) conflicting with my NVIDIA GTX 1050 Ti audio drivers. I recently installed Logitech Z506 5.1. speakers (which were a right pain to set up and then get sound out on all 5 speakers) and have Windows 10 and 11 installed on separate internal drives. I rarely turn my Omen tower PC off, and play music on Spotify or Windows Media player as I go to sleep, so they and the PC are usually in standby mode overnight (this may change now due to the rapid escalation in everyone's domestic electricity costs). When powering off the PC I notice that the audio makes a loud audio 'burp' (in lieu of the technical term for this) during the shutting down and restarting process.
    2022-07-10T16:49:37+00:00
    You should check the chain on this problem. I was lucky to have had my computer replaced and the new computer does not have the delay issue. It is my understanding that the latest updates has solved the problem. Make sure you have run all updates.
    Hope this helps.
    Norma
    2022-07-10T15:19:08+00:00
    I have the same problem! lenovo s340, almost all of the time I hear not the full notification sounds but only an ending part of it. If I pause a video on youtube and then come back after a while and press resume, the video starts playing, but the sound appears maybe in a second or more!!!!!!!!!!!
    If I play the sound with win 11 default media player I don't hear the start of the file at all, sound start in 1 or more seconds of file....
    smth is not right with the audio buffer etc. of course drivers, thoubleshooting disabling enhancements etc doesn't help
    2022-05-03T11:56:51+00:00
    I have dell XPS 13 9310 2-in-1
    I upgraded from windows 10 to windows 11
    I tried several solutions for this
    First, I removed the Realtek Audio driver and kept the wave Maxx, but this didn't solve the problem
    So I removed all, and I downloaded the Realtek Audio driver from dell website and installed it but this didn't solve the problem either
    eventually, I removed all the Realtek Audio driver and Wave Maxx Pro and let the windows do the driver definition with Automatic Windows update, it installed different version than that found in dell website, and this actually solved my problem and now there is no delay and video & audio are in sync for more than a week now
    Make sure that this app is the only Realtek app that installed not 2 of them, because I think that the other one is making the problem
    and The driver software that is found on dell website is not compatible with the driver itself or buggy ![Image](https://learn-attachment.microsoft.com/api/attachments/02f5f3c7-85fb-4d28-9a81-d9ccbe8ea43f?platform=QnA
    2022-05-03T06:52:16+00:00
    Hi all,
    After my feedback above, I again started having problems. I eventually uninstalled the Realtek Audio driver, but kept the Waves MaxxAudio Pro. This seems to have worked - well I will see for how long this works :-)
    So.... for you Window's boffins out there (or you Windows software programmers), my take on it is that there is some clashes within the audio drivers that is causing the problem and this is maybe a place to look. I hope that soon there will be a Windows update that sorts this out.
    Again, I hope this feedback is helping :-)
