Over-exposure in screenshots and recordings with HDR in Windows 11
2022-05-02T14:37:27+00:00
Hello, I am inquiring about an issue I can't seem to solve (without turning HDR off all-together, which defeats the purpose of having it even be an option in Windows 11)
In recordings (primarily using OBS) and in screenshots (with snip and sketch) everything appears extremely over-exposed / bright with HDR enabled. This is a big problem for me as I actually, well, want to use the OS normally. I record lots of clips and take many screenshots and I've finally gotten fed up of it and am now looking for a solution. Any help appreciated, thanks
(snip and sketch has since stopped doing it, however it likes to do it randomly now. commonly happens in fullscreen programs and also my web browser for some reason)
Windows for home | Windows 11 | Display and graphics
    2024-07-20T12:51:03+00:00
    Windows + Alt + PrintScreen works well for me
    Screenshots get saved in %UserProfile%\Videos\Captures in HDR and also reduced to SDR.
    I hate how *this* is the workaround right now in July 2024, but this works for me. I can at least get a screenshot... Thank you!
    2024-07-22T15:05:12+00:00
    This works if you want your entire desktop to be too dark to read print. It doesn't fix the problem.
    2024-07-22T15:22:09+00:00
    Another option that does nothing to fix the issue.
    2024-07-22T17:33:16+00:00
    Fix here
    Just open the Snipping Tool > Tree Dot > Settings > Scroll Down > HDR screenshot color corrector (I'm not sure about this translation, as my Windows is not configured for English.)
    HDR screenshot take with shortcut Win+Shift+S https://learn-attachment.microsoft.com/api/attachments/673e028b-e252-4746-bdb8-765a7357dbdc?platform=QnA&fud_access=hC1SxZhn7m%2FZQJkOIiOVstu10yTQgXS4A%2FDBzZTg8nbaCgIogkrcDydMeI5Y4za2dOqDdWtsG2JNS3E35V60i9TiGHR7STMpJHheeXuDvO8nwjUlqCBHhJ0NDvuYN7OSRdhyzoBNhmeYxCX4n0LBMGkzC1Q%2F1vpehaj2iZLD1Q3R%2FT4wIWpOYNYuUmU4J%2BlipBlndSgz03uk%2BxrL%2FzTjmKF3Cj%2FP%2B%2BkhqPdpoLw0T2DXTZYuvjCercrTpWH5WayyFTfDgHeus7rmRi86%2FBi1e76GnKWwfgPZKfJ716eWv4EskeNx8MQ1lFpyqvgMyG0DzHIwtAOHw%2F5itPupe2Dg8OYQZ5O03K16dAk6S2xFwAMRVdb%2ByMDvj9csIBpOCG6owZF60iHgfQBMztHuQ9%2Fa4XaIQvd3cmN2tV6zu3oTD1o%3D
    2024-07-24T23:22:17+00:00
    This actually works thank you
