Over-exposure in screenshots and recordings with HDR in Windows 11
2022-05-02T14:37:27+00:00
Hello, I am inquiring about an issue I can't seem to solve (without turning HDR off all-together, which defeats the purpose of having it even be an option in Windows 11)
In recordings (primarily using OBS) and in screenshots (with snip and sketch) everything appears extremely over-exposed / bright with HDR enabled. This is a big problem for me as I actually, well, want to use the OS normally. I record lots of clips and take many screenshots and I've finally gotten fed up of it and am now looking for a solution. Any help appreciated, thanks
(snip and sketch has since stopped doing it, however it likes to do it randomly now. commonly happens in fullscreen programs and also my web browser for some reason)
Windows for home | Windows 11 | Display and graphics
    2023-10-23T22:50:00+00:00
    I think Microsoft should turn off Auto HDR off by default, also they should rename it to something better (like "Upscale SDR to HDR function"). Auto HDR is too easy to make people misunderstand it.
    and snip and sketch should have an option to tone-mapping HDR -> SDR too. (like Xbox screen capture that output to 2 files SDR picture and HDR picture)
    2023-11-05T18:43:16+00:00
    Dude do you even use WIndows? do you even work there? or have any idea of windows? the HDR is auto enabling itself EVEN IF IT DISABLED and when i try to record something with xbox game bar the screen just flicker and shuts down..........
    2023-11-05T22:08:36+00:00
    I have tried this. It works for a little bit. But if I lock the screen and come back an hour later, my whole screen is dark again, I have to adjust the gamma settings again. So pretty much every time I unlock my device I need to adjust my gamma settings. This is very annoying. If I launch a game that supports HDR or auto HDR, while the gamma hasn’t been adjusted, the game looks horrible. I have also been using a Mac with HDR, and they have it figured out. I hope Microsoft fixes this issue. We shouldn’t have to adjust gamma settings to “fix” an issue that clearly is a software related issue. I’m using popular Intel/Nvidia hardware. Microsoft should have better support. HDR support is bad.
    2023-11-05T23:01:12+00:00
    It is pretty bad. Games require that you adjust your brightness/HDR calibration within the game. For games that support HDR that’s usually all it takes. It’s either under video or general/game.
    For games that don’t support HDR, you’re generally better off turning off Windows HDR completely. Auto HDR is hit or miss. For some games it works, for most it does not. WIN + ALT + B swaps HDR mode, so if I know a game doesn’t support HDR I just swap back to SDR before playing.
    2023-11-08T19:04:57+00:00
    Thanks for the tip about WIN + ALT + B. Still kind of annoying that I have to manually disable HDR, just to take a screenshot, and then turn it back on every time. I've had this issue for over a year now, I'm surprised it still hasn't been resolved.
