Thank you so much! you solve my issue!
Over-exposure in screenshots and recordings with HDR in Windows 11
Hello, I am inquiring about an issue I can't seem to solve (without turning HDR off all-together, which defeats the purpose of having it even be an option in Windows 11)
In recordings (primarily using OBS) and in screenshots (with snip and sketch) everything appears extremely over-exposed / bright with HDR enabled. This is a big problem for me as I actually, well, want to use the OS normally. I record lots of clips and take many screenshots and I've finally gotten fed up of it and am now looking for a solution. Any help appreciated, thanks
(snip and sketch has since stopped doing it, however it likes to do it randomly now. commonly happens in fullscreen programs and also my web browser for some reason)
Windows for home | Windows 11 | Display and graphics
2023-03-09T15:40:36+00:00 -
2023-03-17T02:20:48+00:00 This worked for me also - thanks!
2023-03-21T11:05:56+00:00 Thanks for the fix. Unfortunately, forcing sRGB color profile removes the ability to watch HDR content in the browser (tested with youtube)
2023-03-21T11:14:01+00:00 Well. I found one work around, but it's only if you Edge. If you use Edge's capture feature there's no issue with the HDR.
2023-03-22T15:34:41+00:00 I noticed another strange behavior. The first chrome window i have opened today is not affected by incorrect colors while taking a screenshot, but the second one is. (not tabs, but windows)
