Over-exposure in screenshots and recordings with HDR in Windows 11
2022-05-02T14:37:27+00:00
Hello, I am inquiring about an issue I can't seem to solve (without turning HDR off all-together, which defeats the purpose of having it even be an option in Windows 11)
In recordings (primarily using OBS) and in screenshots (with snip and sketch) everything appears extremely over-exposed / bright with HDR enabled. This is a big problem for me as I actually, well, want to use the OS normally. I record lots of clips and take many screenshots and I've finally gotten fed up of it and am now looking for a solution. Any help appreciated, thanks
(snip and sketch has since stopped doing it, however it likes to do it randomly now. commonly happens in fullscreen programs and also my web browser for some reason)
Windows for home | Windows 11 | Display and graphics
    2022-05-04T03:48:52+00:00
    Hi ZB06,
    Welcome post in Microsoft Community.
    I'm Mosken, I do apologize for the inconvenience that you're experiencing right now, let me help you sort things out.
    According to your description, I knew that you use the HDR function in Windows 11, overexposure when taking screenshots and screen recordings. If my understanding is wrong, please correct me in the reply.
    First of all, I checked the relevant information and found that the screen recording software you mentioned does not support HDR screen recording itself, but its deficiencies can be compensated by the settings in the software. Because this forum is aimed at individual users of Windows products, I cannot provide you with further support related to the software, but you can check the relevant information on the official forum of the software.
    And about screenshots. Because the screenshot function that comes with the system is only a very basic screenshot and cannot use HDR, it is recommended that you use the screenshot function in the Xbox Gamebar (Open with Win + G).
    The above steps are provided based on the information I have learned so far, I wish that will be helpful to you. If your problem still cannot be solved by these steps, please tell me more specific situation in the next reply. I will continue to assist you in solving the problem.
    Best Regards,
    Mosken - MSFT | Microsoft Community Support Specialist
    2022-07-18T16:33:15+00:00
    Hello.
    Clearly you haven't tested this.
    If HDR is enabled in Windows 11, then ANY screenshot made through print-screen or snipping tool becomes over exposed.
    Here's and example:
    HDR On (made with windows integrated snipping tool):
    HDR Off:![Image](https://learn-attachment.microsoft.com/api/attachments/c9b23fb9-d83d-497b-aab2-b59e0e53dde3?platform=QnA
    No modifications done to the image. Right after snip, i used CTRL V to post it here.
    And the same thing happens with prnt sc.
    This is kind of a huge issue.
    Maybe this is related:
    I'm running latest Windows 11 and the issue still persists. Dell XPS 15 9520 OLED version
    2022-07-18T17:50:52+00:00
    I completely agree that this is a huge issue, to see Microsoft behind the curve yet again with such a trivial issue reinforces my feelings of unsatisfaction with the Windows OS in recent years, things really have gotten that dire all over the OS.
    2022-07-20T05:40:05+00:00
    Hi ZB06,
    Sorry for misunderstood.
    You may try the step follow.
    1. Select the Startbutton, then enter settings. Select SettingsSystemDisplay.
    2. If you have multiple displays connected to your PC, select the HDR-capable display near the top of the screen, and then move the Settings app window to the HDR display that you’re adjusting
    3. On the Display settings screen, select Use HDR.
    4. UnderSDR content brightnessor HDR content brightness, drag the slider to get the right balance for brightness between HDR and SDR content.
    Best Regards,
    2022-07-20T11:22:31+00:00
    That has literally nothing to do with the issue.
    Read my message again please.
    The screenshots and snips become overexposed WHEN USED, not the whole time.
