Many persistent errors in Event Viewer after Windows 11 build 22598.ni_release.220408-1503: "Autopilot.dll wil error was reported"
2022-04-28T20:22:08+00:00
I used to be part of the the Windows 11 Insider Beta channel. After updating to build 22598.ni_release.220408-1503 I began to see the same error in Event Viewer extremely frequently:
The errors are all the same and read as follows:
Autopilot.dll WIL error was reported.
HRESULT: 0x80070491
File: onecoreuap\admin\moderndeployment\autopilot\dll\dllmain.cpp, line 128
Message: NULL
I have never used any program called Autopilot or Modern Deployment. After seeing this problem I immediately left the insider program and am now queued for enrollment. However no new Windows update has happened and these errors persist. How do I prevent these errors?
    2023-05-22T19:02:00+00:00
    Still, no solution! going on and on and on!
    2023-05-23T05:39:07+00:00
    This has worked for me...3 weeks later and no errors. Reset your TPM module.
    If I understood chris__74's 09-Feb-2023 post <above> (and Google Translate is accurate) they were able to stop these errors by resetting their TPM module . I haven't tried that yet, but on my Win 10 OS I assume a TPM reset can be done at at Windows Security | Device Security | Security Processor | Security Processor Details | Security Processor Troubleshooting and then clicking "Clear TPM" or by entering tpm.msc in a Run dialog box (Windows key + R) to open the TPM Management Console and clicking "Clear TPM". Have you tried this possible workaround? If these errors are related to the firmware for the TPM module on the motherboard then that might explain why your Windows 11 reinstall didn't stop the Autopilot.dll WIL errors.
    WARNING*: If you use* Bitlocker Disk Encryption and want to try resetting your TPM module I would advise that you suspend or disable Bitlocker first (e.g., at Control Panel | Security | Bitlocker Drive Encryption for Professional editions of Windows) and ensure that you have your 48-digit Bitlocker recovery key on hand before starting. Bitlocker is currently turned off on my Win 10 Pro v22H2 laptop and I have no idea what unexpected problems might arise if you reset your TPM module while Bitlocker is enabled.
    2023-05-23T13:38:29+00:00
    For chris_74, bonjour, merci pour l'information (now, back to English)
    For TSM007, attempted a TPM reset per the Windows Security process on 23May2023 as suggested by chris_74. The TPM reset was successful, but the Autopilot.dll WIL errors continue. Confirming NVFOX observation "Still no solution!" with my addition of "And none at MS are listening."
    Current device config:
    * Dell Alienware m17 R3
    * Processor: Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz/3.10 GHz
    * Installed RAM: 32.0 GB (31.8 GB usable)
    * Edition: Windows 10 Pro - Ver 22H2
    * OS build: 19045.2846
    All DELL Alienware system diagnostic/configuration bloatware apps are current as of 22May2023.
    2023-05-23T16:56:13+00:00
    Thank you TSM007. Your suggestion (clear TPM) worked for me.
    2023-05-24T21:30:42+00:00
    Good day everyone,
    Before you clear the TPM make sure you do a bit of research at the ramifications of doing this. Especially if you are using Bit Locker. You will also need to log back into your MS account. If you are using a pin to log onto Windows the pin will be invalid and you will need to use your password. You do remember what your password is I hope. Using a pin for a while you could have to go through a lot of pain to reset it. You will also need to reset your pin if you want to continue to use a pin to log on to Windows.
    So I did reset my TPM. Before restarting my PC I cleared the event viewer. When I logged back in it only took about an hour to have 103 errors with only 2 of them NOT being an Autopilot error. I have, so far, 101 errors like this
    HRESULT: 0x80070491
    Message: NULL
    That is 98.1% of the errors dealing with the Autopilot error.
    If resetting your TPM has worked for you then congratulations. I bet there will be more people like myself who are still having this error flood the event viewer.
    Microsoft, get off your duffs and fix this. The event viewer is almost useless unless you filter out the Autopilot errors.
