Many persistent errors in Event Viewer after Windows 11 build 22598.ni_release.220408-1503: "Autopilot.dll wil error was reported"
2022-04-28T20:22:08+00:00
I used to be part of the the Windows 11 Insider Beta channel. After updating to build 22598.ni_release.220408-1503 I began to see the same error in Event Viewer extremely frequently:
The errors are all the same and read as follows:
Autopilot.dll WIL error was reported.
HRESULT: 0x80070491
File: onecoreuap\admin\moderndeployment\autopilot\dll\dllmain.cpp, line 128
Message: NULL
I have never used any program called Autopilot or Modern Deployment. After seeing this problem I immediately left the insider program and am now queued for enrollment. However no new Windows update has happened and these errors persist. How do I prevent these errors?
    2024-09-20T13:52:35+00:00
    Neve asked th8s
    2024-09-20T09:46:10+00:00
    https://geekflare.com/ways-fix-event-id-1001-in-windows/
    step 1 fixed the issue for me 🤟
    Why doesn't Windows have a feature to automatically check for corrupted system files when this error pops up?
    2024-04-08T20:09:25+00:00
    dato meno vecchio è pax imperia mio meglio per pack2 deluso.
