USB power setting is missing from the Power Options (running Windows 11)
2022-04-03T16:35:44+00:00
I am trying to manage my USB power plan settings but the USB option is missing from the Advanced Power Settings option.
Control Panel/System and Security/Power Options/Edit Plan Settings/Change Advanced Power Settings
FYI:
I am running Windows 11 Home Version 21H2 on an HP Spectre laptop.
I tried some fixes posted for Windows 10, but they did not work.
NOTE: I am trying to change the USB power options to see if this will stop the flickering in my Logi HD 1080p Webcam.
    2023-08-15T10:15:33+00:00
    Hey
    Did you manage to solve it? I also do not see the option and tried all troubleshooting from this post. I do see it in safe mode.
  2. Deleted
    2023-12-03T06:52:58+00:00
    I had this issue for an external USB Hard Drive. I fixed it by opening Device Manager,
    Under USB controllers, right-click on USB Mass Storage Device and select Properties. Click on the Power Management tab and uncheck "Allow the computer to turn off this device to save power".
    Now my external HD keeps running instead of powering up and down at the whim of the stupid OS.
    2024-01-14T02:27:54+00:00
    I have the same problem and started just opening management windows.
    I found in device manager that you have to select properties and seen a tab that says power management.
    by default it is selected to turn off when windows chooses.
    hope this helps.
    2024-02-11T20:37:53+00:00
    123456
