Thanks, but there is no such option. Only option is “connection notifications”. And even this does nothing … never see a notification.
USB power setting is missing from the Power Options (running Windows 11)
I am trying to manage my USB power plan settings but the USB option is missing from the Advanced Power Settings option.
Control Panel/System and Security/Power Options/Edit Plan Settings/Change Advanced Power Settings
FYI:
I am running Windows 11 Home Version 21H2 on an HP Spectre laptop.
I tried some fixes posted for Windows 10, but they did not work.
NOTE: I am trying to change the USB power options to see if this will stop the flickering in my Logi HD 1080p Webcam.
2023-04-01T12:14:11+00:00 -
2023-06-20T10:42:02+00:00 See this video :- Disable USB Selective Suspend settings in Windows 11 - Bing video
2023-06-26T09:36:15+00:00 See this video :- Disable USB Selective Suspend settings in Windows 11 - Bing video
NO, that is NOT it. because this guy just shows what is NOT there. read the original post before you answer anything!
2023-08-04T17:55:51+00:00 This doesn't work because there is no usb settings available. It just isn't showing at all. There is no access to these settings in control panel or device manager.
2023-08-11T17:13:55+00:00 Having problems not seeing the USB options myself. Also Windows locks after 15 minutes and no setting I have found will help. No GPOs related to power or interactive login :( Power Plan has 60 minutes set. Registry attributes won't matter.
But back to your USB power options. Have you tried setting the USB suspend options by using powershell or command prompt? This article has the commands at the bottom in "Enable or disable USB selective uspend using Command"
https://www.elevenforum.com/t/enable-or-disable-usb-selective-suspend-in-windows-11.10251/
