I am that that this was able to help you! The crazy thing is that many other computer makers are not offering the most recent driver that works, but are still offering the older one which appears to be corrupt.
WIFI 6 (Mediatek MT7921) disconnects randomly
I just finished building a new pc and installed all the appropriate drivers and software. I have a WIFI 6 router which I have had for a while now and never had any issues with and the motherboard I am using is the ASUS TUF GAMING B550-PLUS WIFI II AM4 AMD B550 SATA 6Gb/s ATX AMD Motherboard. It utilizes the Mediatek MT7921 WIFI card.
The WIFI will randomly disconnect but it says its still connected. Oddly enough I can still load Google and Youtube but nothing else and even then that is intermittent and extremely slow.
Drivers: Ive tried updating, rolling back, deleting and fresh install. no dice
Settings: Ive tried disabling IPV6, Changing from AX to AC to N, etc, Disabled the Bluetooth since its the same adapter. no dice.
Ive even checked to see on another device if my pc is connected to my router while its in this disconnected state and it shows that its connected to my router but it will not connect properly to the internet. I have not had this issue with any other device on my network so I am to conclude that it is most likely to do with this new pc and this Mediatek WIFI Adapter.
Any and all help is greatly appreciated.
2022-05-14T14:58:10+00:00 -
2022-05-20T15:26:49+00:00 That is working! search in "Google MediaTek-FORCED-10x64-79xx_3.03.01.0508-drp" - only one place where I can download it (be carefully, in that website I can see where is the link on from third try only) now version driver is 3.3.1.508 and in "advanced" tab - MUCH MORE settings, than before. So - ASUS make very bad. Sale laptop 2000+ euro and cant make it WORKING (I even not talking about something special - better than another - no, just simple: working)
2022-05-20T18:02:04+00:00 Awesome! I'm glad that it is working for you! Seems like both HP and Asus seem to have bad drivers. I can't help but to wonder if these bad drivers were provided to them by Mediatek...
2022-05-27T21:58:48+00:00 Thank you!
Tested with Lenovo Legion 5 15ACH6H
2022-05-27T22:10:37+00:00 You're welcome. I'm amazed at how many people are finding this solution to work. I'm glad that I shared it!
