How to fix LSA package is not signed as expected event log entries?
2022-09-21T15:03:13+00:00
The home (non-work) desktop was upgraded yesterday to Windows 11 Pro 22H2 and afterwards on every boot there are several errors about LSA package is not signed as expected. How do I fix these errors? The desktop has Secure boot enabled with virtual based security enabled for memory protection. The CPU is an Intel i7 8700K, which meets Microsoft's requirements for Windows 11.
    2023-03-07T10:24:50+00:00
    I'm having the same issue following installaiton of the update KB5022404 at the beginning of February. It appears to be the norm now that I get literally dozens of Errors and Warnings arising after installing any Windows 11 updates. So much for Microsoft's quality control!
    2023-03-07T14:55:52+00:00
    All you need to do is turn off Memory Integrity on the Windows Security-Device security-Core Isolation.
    I was getting no warnings when it was not enabled. As soon as I enabled it and rebooted, I got 10 warnings.
    2023-03-07T19:52:06+00:00
    Turning off a security feature is not a solution.
    However, I had already tried that months ago and still get the errors.
    Win 11 Pro 22H2
    2023-03-10T01:33:23+00:00
    I don't even have Core Isolation turned on as virtualization is not enabled in the BIOS. And Home versions of Windows 11 22H2 don't even support Credential Guard, yet these constant LSA errors every boot up
    2023-03-13T10:13:46+00:00
    Erm, so it appears I have fixed this problem by repairing a different problem entirely. I have tried all the fixes I could find to fix this LSA issue. I had precisely the same problem with 10 events cropping up on startup etc.
    Anyway, I had given up trying to fix it and resigned myself to maybe one day getting an update that'll fix it. I reverted all registry settings and any changes I had made back to what they were before.
    I had a different problem - WLAN Extensibility Module Has Stopped.
    I went into services, made the WLAN autoconfig service start up automatically (was manual), and disabled the (unused) ethernet on my laptop. Control panel > network and sharing > change adapter settings > right-click and disabled the (unused) ethernet.
    Also for a separate issue, I disabled all forms of sharing in Advanced sharing settings which is in settings, not the control panel anymore.
    Anyway, I did all this and both my WLAN error and LSA errors have both stopped!
