Thank you for the log file. According to the content, it contains the security protocol package of the system/third-party software. We have not received relevant reports on the frequent LAS errors after the update of 22H2. Given that it may indeed exist, I suggest you refer to the Feedback Hub to submit the issue to the BUG collection department (Feedback can upload logs and screenshots) so that we can investigate the issue.
How to fix LSA package is not signed as expected event log entries?
The home (non-work) desktop was upgraded yesterday to Windows 11 Pro 22H2 and afterwards on every boot there are several errors about LSA package is not signed as expected. How do I fix these errors? The desktop has Secure boot enabled with virtual based security enabled for memory protection. The CPU is an Intel i7 8700K, which meets Microsoft's requirements for Windows 11.
2022-10-01T03:02:16+00:00 -
2022-09-24T04:55:52+00:00 Could you please provide some screenshots of LAS package signing error? I can help you record this problem. In addition, you can also open the Feedback Hub by pressing Windows Logo+F to submit your situation to the Feedback department so that we can collect information and investigate the problem.
You can always uninstall 22H2 updates from the Windows Update page by clicking "Update History" - "Uninstall updates", then click ***here*** to download the "Hide Windows updates" tool, and run the tool to hide this update (hidden updates will not automatically install updates again). If you decide to upgrade to 22H2 again (perhaps at some point in the future), you can visit the Windows 11 download page to download the Upgrade Assistant update)
2022-09-23T11:33:11+00:00 A clean boot produced the same errors, so I decided to restore the desktop to the previous version of Windows 11 Pro. I might try to upgrade next year or wait until I am forced to upgrade.
2022-09-22T03:29:49+00:00 Hi A123,
Welcome to Microsoft Community.
Could you please provide a screenshot of the error of LSA package? I think this problem may be caused by the fact that the signatures of some services or applications have not been updated after 22H2 update.
I suggest you try aclean boot to see if it works. At least we can find out if the app/service that this error is coming from Microsoft or a third party.
Disclaimer: A “clean boot” starts Windows with a minimal set of drivers and startup programs. It helps to determine whether a background program is interfering with your game or program and to isolate the cause of a problem.
These steps of "clean boot" might look complicated at first glance. However, to avoid any trouble for you, please follow them in order and step-by step so that it will help you get you back on track.
Please feel free to let me know if you got any further updates, thanks.
Best Regards,
Manson - MSFT | Microsoft Community Support Specialist
