WIFI 6 Mediatek MT7921 card not working after June 2022 update
2022-06-22T15:52:34+00:00
I just did the windows update for my Asus Tuf gaming F15 and when my computer booted up again it could not detect any networks (not the networks was connected to, not my phone hotspot or any other unknown network).
The device manage states WIFI 6 Mediatek MT7921 "the device could not be started (code10)"
I have tried:
  • restarting
  • rerolling the update however I have no prior image saved
  • updating the driver (they're up to date)
  • force updating the driver by redownloading them
  • uninstalled and resintalled the drivers
All to no avail, would you help me please ?
Thank you in advance.
2022-06-25T08:02:03+00:00
Hi everyone,
@Brett W Dickason, you should access if you use an ethernet cable (rj45)
I just called Asus french support, to explain the issue.
It seems that the BIOS setting was modified with Windows Update.
The Asus employee made me reset the bios setting and after that, my wifi worked again.
For BIOS version 310 ONLY (i don't know if it's working for other version)
1 - after full booting (and you see the desktop), press the power button for 20s (wait for the 20s even if you have a black screen like the PC is shutdown)
2 - press power button to boot and press F2 until you get to the BIOS.
3 - Press F9 and answer YES to get the default setting
4 - Press F10 and answer YES to save and restart.
5 - PC will reboot by itself and after that WI-FI will be back (well, it's worked for me.)
And for information, the employee told me to use windows update the OS and to use MyAsus for all the other, so I think that I will change the Update Setting in setting.
I hope that this will help you.
Sincerly,
2022-06-22T16:56:38+00:00
Hello DangVS, welcome to the Microsoft community, I'll be happy to help you today;
I understand that the Mediatek MT7921 WIFI 6 device is not working properly;
Initially I recommend that you uninstall the device;
Right click on the start menu and go to Device Manager;
Click (>) Network adapters to expand the session;
Right click on the WIFI 6 Mediatek MT7921 and select Uninstall;
After uninstalling, restart the PC;
Go to the Microsoft Store and download the My Asus app;
Open the app and click on Customer Service;
In the LAN tab, download the latest driver for the wi-fi device;
Go to the location where you saved the driver;
Unzip the files;
Access the folder and open the Setup file to start the installation;
After the installation is complete, try to connect to the Wi-Fi network;
Hope this helps, see you soon!
2022-06-22T22:08:54+00:00
Update on my issue: your suggestion fixed it. I think the first time I didn't do the whole sequence so what worked was:
uninstalling the card in the device manager then restarting and then reinstalling using the .exe driver installer from the asus website
thank you very much for your help =)
244 additional answers
    2022-07-11T00:32:18+00:00
    Thank you. I'll try a lot of methods, reinstall driver, etc.
    but this BIOS method worked for me!
    2022-07-12T03:07:39+00:00
    I have a brand new computer and in the process of everything getting set up and all the Wi-Fi worked fine to start. Then Windows 10 had to do it's update thing. Somewhere in there I remember seeing a BIOS update with "DON'T TURN OFF YOUR MACHINE".
    Shortly after that initial install, the Wi-Fi started having some issues. I received the computer on July 6, 2022, and today is the 11th. I was right at the point where I was thinking this thing had a hardware problem and was in process to send it back. I decided to do some more searches online and ran across this thread. My problems have been identical to those that have folks on here have been posting.
    I looked at the MyASUS app and the suggestion must be for an older version. The current version has "Customer Support", not customer service. There is no LAN tab, and no apparent place to actively download any drivers. When I pull up that app, the driver diagnostic says everything is up to date.
    Over the last several days I fought my way through the driver and device issues with the MediaTek Wi-Fi 6 MT7921 card like everyone else here. I was able to get the wireless to work, but it became increasingly difficult and was definitely NOT stable at all. It would work for a while, though usually until I shut the machine down. When it was started up again no Wi-Fi.
    The BIOS thing though is interesting. I checked my BIOS and it is 310 as well. The update listed in my update history is this:
    ASUS VBIOS Upgrade Utility for FX706HEB V6.60
    I set the bios to the Default (F9), then saved and exited to restart. I think I had to do one more run through with the Wi-Fi setup in "Network & Internet" under "Settings". The did a reboot one more time and the Wi-Fi is working again. Now to see for how long. I will try and touch base back here in a couple of days with results.
    My machine apparently has a hardware problem with the WiFi. It worked better and longer than I think it had before, but again last night no WiFi. Unfortunately, it is now stripped of software and being returned. I have a newer and much better ASUS machine on order, and I believe it has a different WiFi hardware in it. I will post again once it is in hand to let everyone know. I believe the BIOS reset was a bit of a help, but no WiFi means I am not going to keep the machine.
