Scroll wheel in phone link?
2022-07-06T19:25:35+00:00
Phone Link is great to access android apps running on my phone. However, scrolling is very cumbersome. Is there a way to simply use the mouse scroll wheel to scroll rather then having to click and drag with the mouse? If not, is there a place to request this feature?
Windows for home | Windows 10 | Connect Phone and PC
    2022-07-24T20:16:01+00:00
    what's sad is that it was working until the latest update... Scroll wheel worked great, now can't scroll and can't use keyboard arrow keys either.
    2022-07-06T22:09:05+00:00
    Hi, I'm Elise, and I'd be happy to help with your issue.
    There currently isn't a way to do this, but to make a suggestion you can submit feedback on the issue using the feedback hub app, you can find this in the start menu.
    Please let me know if you need any further assistance.
    Kind Regards,
    Elise
