BlueScreen DPC_WATCHDOG_VIOLATION 0x00000133 00000000`00000001 , freeze and after 30 Secounds the BOD comes.
2022-12-26T11:28:26+00:00
made new PC where i get sometimes Blueescreen. First i thought it was the wifi driver, after that i had some days peace. (Yes i use wifi). Under load it did not happen, usally if am browsing or doing nothing.
Changes in Bios: AMD-V,EXPO Profile, Adjusted Fan Curve Silent, Updated to the newest Bios (Since my Fan Cases PMW where always at 1100 RPM).
Inside the Eventviewer i cant get any clue, only before where it says Wifi had connection issues (Critical, so i get a driver from Lenovo, since Gigabyte did not provide the newest.)
Dump File         : 122622-10000-01.dmp
Crash Time        : 26.12.2022 11:58:54
Bug Check String  :
Bug Check Code    : 0x00000133
Parameter 1       : 00000000`00000001
Parameter 2       : 00000000`00001e00
Parameter 3       : fffff800`0cf1c340
Parameter 4       : 00000000`00000000
Caused By Driver  : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+428700
File Description  : NT Kernel & System
Product Name      : Microsoft® Windows® Operating System
Company           : Microsoft Corporation
File Version      : 10.0.22621.963 (WinBuild.160101.0800)
Processor         : x64
Crash Address     : ntoskrnl.exe+428700
Stack Address 1   :
Stack Address 2   :
Stack Address 3   :
Computer Name     :
Full Path         : C:\Windows\Minidump\122622-10000-01.dmp
Processors Count  : 32
Major Version     : 15
Minor Version     : 22621
Dump File Size    : 4.260.447
Dump File Time    : 26.12.2022 11:59:24
So my specs are:
CPU: 7590x AMD
RAM: 2x16 GB 5200 MhZ in EXPO Mode (37-40-40)
MB: Gigabyte X670 ax Gaming
GPU: Saphire Radeon 7900 XTX Gaming
Sound Card: Sound Blaster Z with the new Command Center Software
OS: Win 11 Pro
Dump Files on oneDrive https://1drv.ms/u/s!AmQCcKE8vXedg0ufsIPwZGZZKTea?e=EEWKSh
    2022-12-26T12:32:59+00:00
    Okay thanks, i did right now a clean uninstall with the tool your provided in safe mode. Restarted, disabled wifi, and installed the the amd setup again.
    (I had confirmed both onboard and external over Device Manager where back to the Windows Default Driver, or however it was called.)
    Let's see how long it will take now, to get into it again, or maybe its resolved, or is there where a way to test it out?
  2. David-M 127K Reputation points Independent Advisor
    2022-12-26T12:22:43+00:00
    I use the WinDbg tool to see the data from the minidump files.
    BlueScreenView never gave me the correct information.
    Do you have the drivers for both installed?
    If yes, do a clean install of both drivers.
    This is a resume of the information from your minidumps:
    DPC_WATCHDOG_VIOLATION (133)
    The DPC watchdog detected a prolonged run time at an IRQL of DISPATCH_LEVEL
    or above.
    Arguments:
    Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    DISPATCH\_LEVEL or above. The offending component can usually be
    identified with a stack trace.
    Arg2: 0000000000001e00, The watchdog period.
    Arg3: fffff8042e31c340, cast to nt!DPC_WATCHDOG_GLOBAL_TRIAGE_BLOCK, which contains
    additional information regarding the cumulative timeout
    Arg4: 0000000000000000
    Debugging Details:
    *** WARNING: Unable to verify timestamp for amdkmdag.sys
    SYMBOL_NAME: amdkmdag+225ce41
    MODULE_NAME: amdkmdag
    IMAGE_NAME: amdkmdag.sys
    STACK_COMMAND: .cxr; .ecxr ; kb
    BUCKET_ID_FUNC_OFFSET: 225ce41
    FAILURE_BUCKET_ID: 0x133_ISR_amdkmdag!unknown_function
    OSPLATFORM_TYPE: x64
    OSNAME: Windows 10
    FAILURE_ID_HASH: {ce335412-b260-6bc1-3af9-ea5584f041c4}
    Followup: MachineOwner
    2022-12-26T12:09:59+00:00
    Curious question, where you see it which driver is causing this problem? Since Bluescreenview, did not help me (Or i dont know how use it corretly)
    And which one the onboard gpu or the external?
  4. David-M 127K Reputation points Independent Advisor
    2022-12-26T12:08:11+00:00
    Hi. I'm David, and I'm happy to help you.
    Your minidumps indicate the driver "amdkmdag.sys" as causing the crashes. This driver belongs to your video card.
    I suggest you do a clean install of the drivers.
    Download the latest driver for your video card from the AMD website. Then use the free DDU tool to remove the current driver. Then install the latest driver using the installer you downloaded.
    DDU: https://www.guru3d.com/files-details/display-dr...
    AMD driver download: https://www.amd.com/en/support/graphics/amd-rad...
    See if the system will work stable after this.
    Feel free to ask back any questions.
    ________________________________________________________
