I'm actually beginning to wonder whether it's a power-related HDMI/HDCP issue. AFAIK I have only had this problem with monitors connected via HDMI (not DisplayPort). Has anyone had the problem with a monitor connected via DP?
My theory is: a temporary fluctuation in the power supply may prompt the HDCP "handshake" (between the display adapter and the monitor) to be repeated, causing the display to go blank until the handshake is completed. This usually takes a few seconds. I used to have a Humax PVR which did something similar - my TV would go blank for a few seconds while the HDCP handshake repeated itself.
