For me helped to change refresh rate, was 60Hz, changed to 59,94Hz.
System>Display>Advanced display>Choose a refresh rate
I am working off of a laptop and have a second monitor to extend my displays. I have been using this set up for two years now and have not had a problem until last night. It seems that my attached monitor only (main monitor on laptop is not affected) will go black for a few seconds before turning back on and showing my screen. It should be noted that my laptop does not reset the display to place the windows back onto the main screen when this happens but the extended monitor goes black at random. Note that I am running Windows 10 and unable to upgrade to Windows 11 as of now.
So far, I have tried the following solutions but still cannot figure this out.
This means I have spent time replacing and even buying new equipment to get around this issue but cannot seem to figure it out! This is very important since I work at home as well. Please let me know if there is anything else I can possibly do outside of hard resetting the computer (which I cannot do for a few reasons). Thank you!
For the few people running high refresh rate displays, it wouldn't be ideal to lower refresh rate to 60hz or lower. It's just a workaround.
I have the same issue.
4k120hz and 1440p120hz both are capable of HDR and 144hz.
For minor stability, I had to drop them both to 120hz, HDR turned off.
My 1440p monitor flashes randomly black. It's the worst when set to 144hz
Both monitors connected to a RX6800XT
Hi I have the same problem and have 2 graphics cards on the laptop a Nvidia and an Intel. Lowering the resolution won't shorten the screen?
All - I had the same issue with two monitor pairs (one at work, one at home) being fed by my Lenovo P15 through TP3 docking stations. Since the same thing happened (monitors would go black for a few seconds and then come back) with two completely different sets of monitors/cables/docking stations it seemed my laptop was the common item. I was on Win 10 and the problem was happening, and then was upgraded to Win 11 and it continued to happen, so it ruled out a specific operating system (but of course both are still Windows). I had run Windows Updates to make sure I had the latest, including Advanced Updates to include all drivers. Nothing helped. I opened a ticket with our support team and one of the techs confirmed everything I had done and then decided to try to update the Nvidia drivers. He used a program called 553.35-quadro-rtx-desktop-notebook-win10-win11-64bit-international-dch-whql. I believe he ran it to update all the drivers and since then the monitors have not gone black once in the past four days. I'm pretty much ready to consider this a permanent fix. BTW - at work both monitors were connected via HDMI. At home one was connected via HDMI and one was connected via DP, but that didn't seem to matter one way or another. So if you have a Nvidia GPU maybe this will give you something else to try...
Thanks, Jim. I have tried NVIDIA drivers from NVIDIA and from Lenovo. Have not helped. Please post if your issue returns.
I did not think RTX Desktop Manager had anything to do with drivers. Just to manage more than one monitor and what appears where. I shall look, but would be surprised if something there was pertinent.
