Second monitor keeps on temporarily going black at random
2023-01-08T02:47:33+00:00
I am working off of a laptop and have a second monitor to extend my displays. I have been using this set up for two years now and have not had a problem until last night. It seems that my attached monitor only (main monitor on laptop is not affected) will go black for a few seconds before turning back on and showing my screen. It should be noted that my laptop does not reset the display to place the windows back onto the main screen when this happens but the extended monitor goes black at random. Note that I am running Windows 10 and unable to upgrade to Windows 11 as of now.
So far, I have tried the following solutions but still cannot figure this out.
  1. Bought brand new chords (HDMI + Adapter)
  2. Bought a brand new second monitor (issues happening with both old and new monitor)
  3. Checked for updates on all drivers
  4. Reinstalled both graphics drivers
  5. Rolled back graphics drivers
  6. Checked basic settings (sleep/power/screen saver settings)
  7. Disabled all services in background apps in "System Configuration"
  8. Restarted Windows explorer
This means I have spent time replacing and even buying new equipment to get around this issue but cannot seem to figure it out! This is very important since I work at home as well. Please let me know if there is anything else I can possibly do outside of hard resetting the computer (which I cannot do for a few reasons). Thank you!
    2024-03-19T21:10:04+00:00
    Check for your graphics card I accidentally deleted my graphics card that’s why
    2024-03-19T21:56:05+00:00
    May have a (hopefully temporary) fix for some of you out there;
    I didn't read through whole thread past the first page. This just started happening to me after the latest KB Update as of todays date (KB5035845) since KB5034441 fails to install for me. My set up is as follows:
    :pcbs_cpu: i9-7900X
    :pcbs_motherboard: ASUSTeK PRIME X299-DELUXE (LGA 2066 R4)
    :pcbs_gpu: EVGA RTX 3080
    :pcbs_ram: 32 GB DDR4-2666
    :pcbs_hdd: 1 TB Samsung 970 Plus MVNE SSD
    :pcbs_hdd: 2 TB Samsung 870 EVO SATA SSD
    :pcbs_psu: ASUS ROG STRIX RGB 1000W Gold
    :SonicManiaItemBox: #1 LG 48 inch 4k OLED (48C1AUB)
    :SonicManiaItemBox: #2 ViewSonic 32 inch 4k HDR Monitor
    After trying most of the things listed here, and them not working, I tried =
    Nvidia Control Panel > Display > Set Up G-SYNC(tm)
    I selected my second monitor (ViewSonic 32 inch 4k HDR Monitor) and then unchecked "Enable G-SYNC, G-SYNC Compatible"
    (This was previously checked "On" with the sub option "Enable for full screen mode" selected beneath it)
    Hit Apply
    Suddenly my second monitor has stabilized. I'll Update here if there's any change. Hope this helped at least one person.
    2024-03-19T23:11:09+00:00
    I have just found a graphics card update, Intel® Graphics Driver 31.0.101.5333.
    I've installed it & so far so good.
    Will update asap to let everyone know how it goes
    2024-03-20T22:03:44+00:00
    This update did not resolve the issue.
    Does anyone know how to fix this?
    2024-03-21T12:29:09+00:00
    I haven't found a definitive solution. But there is something that may help to live with it.
    When the issue starts happening, press Win+Ctrl+Shift+B to force the GPU driver to reset. It may crash some of your open apps so save your work before doing this.
    It will stop the issue for a while, until it happens again... But to me it will hardly happen again in the same day if I don't restart the system.
