Stop code: IRQL not less or equal
2023-01-10T21:34:43+00:00
Hello guys, I'm Martyn, these days my laptop go wrong. I didn't do anything, but I will receive "Blue screen of death" everyday with "IRQL not less or equal"; "system thread exception not handled"; "kernel security check failure" and some other BSOD. I checked my drivers and they're all in the latest version, I reseted my computer and nothing happened. So how can I do to fix those problems?
Thanks for spending time on my problems!
    2023-01-15T02:22:03+00:00
    still get crashed (not BSOD), I have no idea...
  2. DYARI BARHAM 37,681 Reputation points Independent Advisor
    2023-01-15T14:11:10+00:00
    kindly share the Event viewer logs:
    https://www.yourwindowsguide.com/2017/12/how-to...
    Regards,
    ____________________________________________________________
    2023-01-15T19:29:57+00:00
    Here's the OneDrive link:
    https://aumontgomery-my.sharepoint.com/:u:/g/personal/cma1_aum_edu/Ea13XAgxJaRMnLnJFC0HMvIBITpEECfMpPyJPqVPr_VKkw?e=dup1a5
    One more thing, my laptop went into BSOD "IRQL-Not-Less-Or-Equal" and "System-service-exception" (caused by win32kfull.sys), here's the Minidump file: https://aumontgomery-my.sharepoint.com/:f:/g/personal/cma1_aum_edu/EmlN0EF3TB9MrnwomhFmcyQBM5SSoJ17BH4nzClPyDUFmQ?e=M4k55L
  4. DYARI BARHAM 37,681 Reputation points Independent Advisor
    2023-01-16T07:57:50+00:00
    Hi Martyn,
    Thanks for sharing the files.
    The minidump files indicate hardware issue. Before asking you to take the computer to a maintenance shop, I would like to double-check it by enabling Driver Verifier.
    Please enable the driver verifier and let the computer crash 3 times then disable it and share the newly created minidump file:
    https://www.tenforums.com/tutorials/5470-enable...
    Please do not hesitate to ask if you need further assistance.
    Stay safe.
    2023-01-16T20:34:24+00:00
    So what will I do is to enable the "Driver Verifier", crash my computer 3 times, disable the "Driver Verifier", and share the minidump file right?
