Damm, my laptop just went BSOD again "irql not less or equal" again... I will try to find latest drivers, but I used "Driver Booster 10" and it shows that all my drivers are all in latest version...
Stop code: IRQL not less or equal
Hello guys, I'm Martyn, these days my laptop go wrong. I didn't do anything, but I will receive "Blue screen of death" everyday with "IRQL not less or equal"; "system thread exception not handled"; "kernel security check failure" and some other BSOD. I checked my drivers and they're all in the latest version, I reseted my computer and nothing happened. So how can I do to fix those problems?
Thanks for spending time on my problems!
2023-01-11T01:46:54+00:00 -
Jan J.23 13,925 Reputation points Independent Advisor2023-01-11T01:52:09+00:00 Try to fully uninstall the driver booster, this can also cause driver conflicts. And download the drivers directly from the Manufacturer's support website. If you have any cleaners/driver downloaders or third-party antivirus installed. Fully uninstall them using their uninstall tool.
2023-01-11T01:53:31+00:00 Got it, I'll try.
Jan J.23 13,925 Reputation points Independent Advisor2023-01-11T01:55:01+00:00 I hope this helps. Feel free to ask back any questions and keep me posted.
2023-01-11T02:03:09+00:00 While I was downloading drivers, BSOD again, this time is "Kernel Security Check Failure", is this related to what I encountered before?
Also, when I was installing NVIDIA VGA Driver, it seems some files in "C:\WINDOWS\Tempinst\is-5M8QB.tmp\Display.Driver" was "The source file is corrupted", so is this the problem?
