RealTek Extension Downloads Not Working
I use Windows 11 and this morning I got some notifications that I needed to download some RealTek extensions but they are not working, The three are:
Realtek - Extension - 9.21.3690.427
Install error - 0x80070103
Realtek Semiconductor Corp. - Extension - 6.0.9366.1
Anyone know why this is happening and if the update it legit or not?
2022-10-24T03:49:29+00:00 -
2022-10-26T01:20:10+00:00 Well, the suggested fix doesn't work for me. Any other ideas?
2022-10-26T01:21:30+00:00 I tried this twice, but I still have the error and cannot update the Realtek extension. Have you found any other solutions to fix the error message?
2022-10-26T01:24:18+00:00 Have you been able to fix it yet? I have tried twice, but still get the error. Any other suggestions for fixing the error and updating the Realtek extension?
2022-10-26T16:28:52+00:00 I ran the Win UD Troubleshooter, left it do its thing. Closed out and then rebooted. I made a point not to re-check for about an hour (no rhyme or reason to duration, just let time pass).
The next time I did check, all was well and the two culprits, pictured below had installed successfully.
Sometimes the bull wins :)
