HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331 update doesn't install.
2022-10-30T05:09:35+00:00
Hello there,
"HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331" is an update that is really annoying me. It has always been there since the day I got my laptop. (Its been over a year)
At first, whenever I would check for windows update, this update would pop up every time, and would install and go away. Every time. This happened every single time I checked for an update.
Yesterday, I checked for an update, and sure enough, this update popped up. But instead of installing and going away, it gave me an install error. And no matter how many times I retry to install it, it doesn't install and keeps on giving me an install error.
I cant even check for updates now, unless this thing is installed.
Any help would be appreciated. Thank you in advance!
John DeV 170.4K Reputation points Independent Advisor
2022-10-30T05:40:39+00:00
Hello Roshaan,
Good day! I'm John Dev a Windows user like you and I'll be happy to assist you today. I know this has been difficult for you, Rest assured, I'm going to do my best to help you.
Note: It is always recommended to download and install drivers from the manufacturer's Support page. If you're not experiencing any hardware issues, there's no need to install this driver update.
Please try using the “Show or Hide Updates” troubleshooter to hide the driver updates. Window Update won’t install hidden drivers or updates. Run the troubleshooter then please try hiding the driver updates that will show in the list. You may try restarting your pc if it helps.
http://download.microsoft.com/download/F/2/2/F2...
Kindly let me know if this helps or if you have any further concerns.
Kind regards,
John DeV
Independent Advisor
42 additional answers
    2024-06-03T13:48:58+00:00
    HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331 error coming not being updated.
    My printer scan is not working
    2024-08-16T16:40:41+00:00
    What you need to do is remove the incomplete installation of an HP printer from your printers list
    On Windows 11 go to
    1. Settings - Bluetooth and devices
    2. click on View more devices
    3. Scroll down and find More devices and printer settings and click on it
    4. Find the HP printer with incomplete installation, right click and select Remove device
    5. Go to Windows update
    6. In the Pause update section, select pause for one week or whichever you want
    7. Wait for the pause update to be applied
    8. Hit resume updates, and you will not see the nasty printer notification you mentioned above.
    I hope it works for you as it worked for me
    2024-09-18T13:12:21+00:00
    why can not update driver HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331
    2024-11-08T13:05:35+00:00
    This failed during window update as a result my laptop showing no audio device installed
    Volume not audible
