HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331 update doesn't install.
2022-10-30T05:09:35+00:00
Hello there,
"HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331" is an update that is really annoying me. It has always been there since the day I got my laptop. (Its been over a year)
At first, whenever I would check for windows update, this update would pop up every time, and would install and go away. Every time. This happened every single time I checked for an update.
Yesterday, I checked for an update, and sure enough, this update popped up. But instead of installing and going away, it gave me an install error. And no matter how many times I retry to install it, it doesn't install and keeps on giving me an install error.
I cant even check for updates now, unless this thing is installed.
Any help would be appreciated. Thank you in advance!
John DeV 170.4K Reputation points Independent Advisor
2022-10-30T05:40:39+00:00
Hello Roshaan,
Good day! I'm John Dev a Windows user like you and I'll be happy to assist you today. I know this has been difficult for you, Rest assured, I'm going to do my best to help you.
Note: It is always recommended to download and install drivers from the manufacturer's Support page. If you're not experiencing any hardware issues, there's no need to install this driver update.
Please try using the “Show or Hide Updates” troubleshooter to hide the driver updates. Window Update won’t install hidden drivers or updates. Run the troubleshooter then please try hiding the driver updates that will show in the list. You may try restarting your pc if it helps.
http://download.microsoft.com/download/F/2/2/F2...
Kindly let me know if this helps or if you have any further concerns.
Kind regards,
John DeV
Independent Advisor
42 additional answers
    2023-06-16T08:20:02+00:00
    Hello there,
    我也同样遇到了这个问题
    我先在控制面板删除所有有关的打印机
    我的打印机是HP M28w
    然后卸载了打印机驱动程序
    回到Windows 更新中点击暂停一周更新在选择继续更新
    然后就没有这个问题了
    可以通过Windows内置添加打印机的方式添加打印机
    2023-09-23T11:34:20+00:00
    J'ai également rencontré ce problème
    Je supprime d'abord toutes les imprimantes concernées dans le panneau de configuration
    Mon imprimante est HP 135wg
    Puis désinstallé le pilote d'imprimante
    Revenez à Windows Update, cliquez sur Suspendre les mises à jour pendant une semaine, puis sélectionnez Continuer les mises à jour.
    Alors il n'y aura plus ce problème
    Vous pouvez ajouter une imprimante via la méthode d'ajout d'imprimante intégrée à Windows.
    I also encountered this problem I first remove all affected printers in Control Panel My printer is HP 135wg Then uninstall the printer driver Go back to Windows Update, click Pause updates for a week, and then select Continue updates. Then there won't be that problem anymore You can add a printer using the Windows built-in method of adding a printer.
    2023-09-26T15:54:47+00:00
    HP-USB-12/10/2018 12.00.00 AM-49.0.4411.18331
    Yükleme hatası - 0x80070103
    2023-09-27T09:39:04+00:00
