HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331 update doesn't install.
2022-10-30T05:09:35+00:00
Hello there,
"HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331" is an update that is really annoying me. It has always been there since the day I got my laptop. (Its been over a year)
At first, whenever I would check for windows update, this update would pop up every time, and would install and go away. Every time. This happened every single time I checked for an update.
Yesterday, I checked for an update, and sure enough, this update popped up. But instead of installing and going away, it gave me an install error. And no matter how many times I retry to install it, it doesn't install and keeps on giving me an install error.
I cant even check for updates now, unless this thing is installed.
Any help would be appreciated. Thank you in advance!
John DeV 170.4K Reputation points Independent Advisor
2022-10-30T05:40:39+00:00
Hello Roshaan,
Good day! I'm John Dev a Windows user like you and I'll be happy to assist you today. I know this has been difficult for you, Rest assured, I'm going to do my best to help you.
Note: It is always recommended to download and install drivers from the manufacturer's Support page. If you're not experiencing any hardware issues, there's no need to install this driver update.
Please try using the “Show or Hide Updates” troubleshooter to hide the driver updates. Window Update won’t install hidden drivers or updates. Run the troubleshooter then please try hiding the driver updates that will show in the list. You may try restarting your pc if it helps.
http://download.microsoft.com/download/F/2/2/F2...
Kindly let me know if this helps or if you have any further concerns.
Kind regards,
John DeV
Independent Advisor
42 additional answers
    2024-12-22T09:49:31+00:00
    Hello there,
    Im wesam
    2024-12-22T09:50:25+00:00
    Please solve the problem as soon as possible
    2025-02-10T06:14:29+00:00
    0x80070103 error message
    2025-02-26T03:26:30+00:00
    Привет,
    "HP - USB - 12/10/2018 12:00:00 AM - 49.0.4411.18331" - это обновление, которое меня действительно раздражает. Оно всегда было там с того дня, как я получил свой ноутбук. (Прошел уже год)
    Сначала, когда бы я ни проверял обновления Windows, это обновление каждый раз всплывало, устанавливалось и исчезало. Каждый раз. Это происходило каждый раз, когда я проверял обновления.
    Вчера я проверил наличие обновления, и, конечно же, это обновление появилось. Но вместо того, чтобы установиться и исчезнуть, оно выдало мне ошибку установки. И сколько бы раз я ни пытался его установить, оно не устанавливается и продолжает выдавать мне ошибку установки.
    Я даже не могу проверить наличие обновлений, пока эта штука не установлена.
    Любая помощь будет оценена по достоинству. Спасибо заранее!
    Эту функцию как удалить с обновление
