Well, it failed on me again a few days ago. So far the only solution has been to go into my Link to Windows on my phone, disable SYNC CONTACTS AND RENABLE IT and then I reboot my computer and phone. So annoying. Never had this problem before. I had other strange quirks but not this one.
Phone Link "Messages" shows phone numbers, not names and photos
I use Phone Link on my Windows 11 PC to text message through my Samsung S22+ phone. I use the desktop Outlook client on my PC and have my Outlook contacts synchronize with the Samsung Contacts app on my phone. A couple of months ago, I began to notice that the names and photos of some of the people with whom I text were no longer showing up in the Phone Link "Messages" list; just their phone numbers. Also, when I clicked "+ New message" in Phone Link, and typed their name, they never showed up in the list of matching contacts from which to choose. This was very frustrating, especially since those contacts were the ones with whom I text most often.
I tried just about everything I could think of - uninstall/reinstalling Phone Link on the S22+ and my PC, multiple syncing options, etc., all to no avail. Then I noticed that the format of the number that showed up in Phone Link was different than what I had in my Outlook contacts. The numbers in Phone Link all showed up with a leading "+1" and had a dash after the area code without parentheses, like this: "+1 123-555-1212" but the numbers in Outlook Contacts showed up like this "(123) 555-1212". I thought the issue might be a database lookup problem, so I tried to enter the same number format in Outlook that appears in Phone Link: "+1 123-555-1212". But Outlook would NOT let me enter this format! It automatically put parentheses around the area code and removed the first hyphen, like this: "+1 (123) 555-1212".
When the new contacts manager for Outlook.com (Outlook on the web) was launched a short while ago, I used the Contacts editor on those contacts and WAS SUCCESSFUL in entering the phone number in the exact format that appears in Phone Link: "+1 123-555-1212". When I sync'd my contacts to my phone, PRESTO! The names and photos of those contacts reappeared in Phone Link "Messages"! So, if you are having problems seeing a phone number instead of names and photos in the Phone Link "Messages" app, try this!
Windows for home | Windows 11 | Connect Phone and PC
2023-01-30T21:59:24+00:00 -
2023-01-31T01:16:11+00:00 This is a formatting issue I figured out yesterday.
Phone Link is demanding full phone numbers with international codes.
My (555) 555-5555 number for someone is now empty.
If I change my Google Contacts to +1 555 555 5555 and save, exit Phone Link, let it re-connect and sync, it now works again.
2023-01-31T01:23:25+00:00 That part only partially makes sense. Because for me it has gone back and forth in doing this and why disappear the names?
Deleted
2023-01-31T03:56:14+00:00 found it! https://www.intel.com/content/www/us/en/products/docs/unison/overview.html great to have an option to test. So sad Phone Link has been so painful to deal with a very basic operation. I hope they fix it just because it comes with the operating system.
Could not find it by searching "intel unision" but this link works
https://apps.microsoft.com/store/detail/intel%C2%AE-unison%E2%84%A2/9PP9GZM2GN26?hl=en-us&gl=us
It looks like it was written right on top of Microsofts Phone Link app. but you are correct, the contacts seem to be matching.
Links:
