Quick Access not showing in navigation pane since Windows 11 update
2022-10-07T05:34:35+00:00
I updated to the latest version of Windows 11 yesterday. When I opened File Explorer, Quick access and recent files/folders were showing to the right of the window, but the Quick Access folder option was missing from the navigation panel on the left. So if I click away from this Window I've lost Quick Access. How do I re-enable Quick Access to the left part of the navigation pane?
Please look at the screenshot before replying. Quick Access is enabled in view mode options and can be seen, but is missing from the left side of the navigation pane.
Thanks for any help.
    2024-05-28T15:10:36+00:00
    The Trick is to uncheck "Show recommended section". Otherwise "frequently used folders" won`t be able to stay checked.
    2024-06-06T23:27:07+00:00
    I still can't find it. This is very frustrating. Please HELP!! I need step by step instruction.
    Relondia
    2024-06-07T14:54:20+00:00
    In the command bar click on the three dots
    then Options -> View -> scroll down in Advanced settings window -> Navigation pane -> uncheck "Show all folders"
    Hopefully afterwards you can see the Quick Access again
    2024-07-10T06:06:01+00:00
    So true, hating windows 11 here.
    2024-07-11T14:35:51+00:00
    I've recently downloaded Windows 11 and my Quick Access is missing too. You said Quick Access is now found by clicking Home option in the navigation pane.
    Here is my Home option clicked and to the right, Quick Access is nowhere to be found. How do I find Quick Access?
